rnscustom
Hi , been a while since I’ve been on here . I just purchased a Miller Vintage . I’m having what I believe is an issue with the wire feed . It seems to stall on the lower speeds but it’s fine up faster . It will rotate on low if the tension is not applied / sometimes it will push a little but seems like it’s slipping ( not the wire slipping but the motor ) but won’t push the wire . Not that I should be doing it but if on lower speeds I can stop the roller but on the higher speeds I can’t stop it . Brushes are new looking . Have a liner on order but I think that’s out of the equation . Question is should I have less torque on lower speeds . I would guess it might have a little but not enough to effect the overall wire feed performance . Anyone have an idea what could be the issue . This is a new to me machine that was put away wet and I’m cleaning it up Thanks , Richard
