Milling 8020 countersinks
jgorm
San Diego
Does anyone have any tips on milling 8020 countersinks? I had the mill on the slowest speed and the aluminum seemed to pack up on the bit. It was fairly difficult to remove. Oil just seemed to make everything messier. I'm definitely not a machinist so I'll appreciate any tips.
BuffettFan
Central Illinois
Jeff95TA
Pittsburgh, PA
I'm interested in this too even though I'm only going to have to do some thru-holes and countersinks. I took the easy way out and bought the members pre-machined for the miter joints and the anchor fasteners.
Bigblue&Goldie
First off, I'd guess you are turning that end mill way too slow. Check this website to figure out what RPM range you should be in.
https://www.wisc-online.com/LearningContent/mtl8202/MLT8202.htm
Next, an end mill isn't a drill bit, so they don't extract chips in the same way. The longer you let that end mill turn in there the more the chips will rough up the finish. Get in and get out. Try lubing everything up with WD40 and you should get less sticking.
larry_g
oregon
Agree with to slow. Your rubbing your way through and building heat allowing the AL to melt and fuse to the cutter. Try an uncoated 2 flute with WD40 for a lube. You should be throwing chips.
lg
no neat sig line
Doug Arthurs
Ontario
yes WD-40 will help and speed up the rpm and feed rate. Also an endmill designed for aluminum would be much better or at least a 2 flute.
MattT
First off that's a counterbore you're cutting not a countersink. Like the other guys said you look to be running slow. And WD-40 for a lube.
Bright finish end mill would probably do better. Or whatever the latest and greatest surface treatment for Al is this week. I wouldn't go down to a two flute for that application though, because then you'll be cutting intermittent.
cmandp
New Jersey
Looking at your chips it looks like your endmill is more munching through than really cutting. Like others said it looks like your spindle speed is too slow. But I would also make sure your endmill is sharp and use a cutting lube. WD40 is good as you most likely have it handy, straight kerosene or something fancier like Alumatap would be good as well.
J
jgorm
San Diego
Thanks guys! I'll try wd40 and doubling the speed. 8020 sells a bit for this but it's 50 bucks and I'm thousands into this project already.
kasander
Wilmington, NC
If you aren't married to 8020, check out www.tnutz.com. If you are purchasing new material and know your lengths and where you need the counterbores machined, much cheaper to purchase them already machined. The counterbores are 75 cents each...
J
jgorm
San Diego
Do the profiles match up with 8020? I got loads of 8020 for free with 2 buckets full of fittings.
larry_g
oregon
I've had a bunch of experience with different brands of extrusions and find that most do not interchange. Just some slight difference in the slot profile will prevent hardware from fitting correctly. Once many years ago I found on the internet a chart of the different profiles that could be used to identify the manufacture. Search it out. I'd also talk with the tnutz people and have them confirm that it is the same profile and all the hardware will interchange. Then if they confirm that, check if it is a Chinese knockoff and then wonder if the hardware is up to you standards. Request samples.
lg
no neat sig line
manwithtools
Lebanon, TN
Speed up, WD-40, 2-flute if you have it. Coating does not matter in this application. Don't be afraid to feed it pretty fast as well. That's soft stuff, got to make chips. Practice on scraps.
Not worth the hassle to look for interchange hardware as larry_g mentioned.
kazlx
Tustin, CA
2 or 3 flute. Spin it as fast as that mill will go. Spray a little WD-40 on there for lube. A good EM will go through that like butter. A little corner radius will be stronger and hold up better than a sharp one, even if it's small, especially on plunge cut with gaps like that. You're definitely rubbing too much. Also, don't want to have to point out the obvious, but just make sure it's a center cutting endmill as well...
J
jgorm
San Diego
My milling experience is pretty much nothing. All my bits came with the mill when i bought it used. How do i tell if it's center cutting or not?
I might try some tnutz. Thanks for the tip!
kazlx
Tustin, CA
The flutes on the bottom, two of them should go all the way to the middle. What size are you using?
bullnerd
Jersey
Those extrusions are made out of some seriously gummy **** metal!
Probably has some type of coating on it too which doesn't help, like anodize.
I used to build scanning bridges out of that **** for years.
The bosch style was the best.(I think it was Bosch, I used them all.) Just tap the hole in the end and you could mount it anywhere. No need to spotface anything.
Like Kaz said, as long as that end mill is center cutting it'll work.
Keep at it, you'll get the hang of it.
kasander
Wilmington, NC
Anchor fasteners with counterbored holes are the way to go. Much stronger than tapping the ends...
J
jgorm
San Diego
Thanks! Tapping the ends requires drilling access holes when you move it. I'm using 4 counterbore fittings on each connection. Probably overkill, but that's what i do.
bullnerd
Jersey
Not the ones we used.
The threaded end held a metal bracket that fit in the "T".
I've done the through hole ones too. I used to jam a 3/8-24 bolt through them. It was plenty strong. lol!
kasander
Wilmington, NC
How did you tighten it if you thread the a stud into the end and the other end is captured with a Tnut?
bullnerd
Jersey
Sorry, Mini tec, not Bosch, Bosch came later. I started building xyz ultrasonic scanning bridges with this stuff in about 91'.
One of the brands is waaay easier to use than the others, but I forget which one.
For basic ****, the minitec was the best. Plenty strong.
None of this is going to help the OP though.
J
jgorm
San Diego
I cranked up the speed and got them done way faster. I could make a counterbore in <1 sec, but then i had to use needle nose to pull the metal off the bit. I got 64 of them done and have a 2 flute on order along with a bunch of tnutz fittings. Tnutz has 8020 equivalent part numbers. I spent 150 bucks, but probably saved 200 over 8020 direct. Thanks for the tips! It doesn't look like a full days work but my cnc plasma table base is almost done!
