Milton V-style Couplers Hard to Operate
bfr57
So, moving my compressor into my other garage I decided to switch everything over to the Milton high flow V-style couplers and *******. I've noticed they are very hard to connect together. Is that indicative of these couplers? My son can barely get air tools connected and it's a little workout for myself!
Radix2
the thumb!, MI
That's odd, the nice thing about the v connectors is that you don't have to pull back the collar to insert, you just push the connector in.
...is the problem the pressure is so high it makes it too hard? How about unpressurized connections? Any different?
Jeepster04
I imagine it is the pressure thats making it hard to engage them. My V's are pretty tough to push in but the ones I have laying around that area on a hose can easily be pushed in.
Leveleer
Superior/Duluth
The answer is here.
sberry
Brethren, Michigan
"better" strikes again. I had considered something easier. but am going to use what I have. Most career types I know including a couple master plumbers still use the same stuff they started with.
Trey T
Houston, TX
Go with these types:
Milton safety coupler
Husky safety coupler
Those are the poorman's Prevost version. HF has their own knock-off but they're poorly made, won't seal properly after short while. The Husky is very well made and cheap. I don't have Milton version but I think it should be on par with Husky or better.
bfr57
I didn't see on Milton's site where they have a safety coupler for "V" high flow?
Did I miss it?
gearhead1
NC
It wasn't V Milton, but the regular style I had that wore out quickly. I still have some HF ones that do not leak that outlasted the Milton. The Milton didn't leak but was near impossible to connect and disconnect. ***** because Id rather buy US/Canadian made stuff.
justanengineer
Motor City
Over 40 dollars apiece? Yikes! I bought 2 from Amazon for that price.
They are not high flow either.
Meh, $40 is the Fastenal list price for each, nobody pays that and nobody's likely to buy one either. I'd expect them to be ~$25 each which yes is still pricey for many but these last significantly longer than Miltons IME and certainly flow more. Mine were work freebies, the best variety. :p
To each their own tho, I'm not out to argue HF vs SO with folks here.
NewShockerGuy
Northern Virginia / DC
I love my Prevost safety couplers. I've had them for years now. Super easy to connect and disconnect things. I have a normal quick connect on my little tiny portable air compressor and it's such a pita connecting things on top of making a loud pop when you disconnect things. It makes me realize why I paid the 20 bucks for the Prevosts.
-Nigel
Leveleer
Superior/Duluth
-Nigel
Prevost is a good coupler. What I don't especially like about the S1 is the physical size and the insertion force which is about 30 pounds at 120 PSI.
sberry
Brethren, Michigan
I did have some issues with different brands of the same couplers, Seems I recall the Parkers didn't want to seal against the Miltons.
OutlawDrifter
KS
I switched to Milton V's a year ago or so. At higher pressures it does take more effort, but not enough to go back to a lesser fitting.
ItsNemo
Canada
It makes perfect sense, you're pushing against pressure of a larger opening...they aren't that hard, you just need to use two hands.
Nexussian
Alaska
"Aren't that hard" is a matter of perspective.
I've used many types of air couplers, while some are more of a PITA than others, ones I've had no difficulty with are potentially dangerous to my father (he's in his 80s).
If you follow the link posted earlier about "answers" there is a YouTube video linked with a "force test" of a Milton V coupler.
The author uses a load cell to push the coupler to full engagement, it took over 400Lb of push. :eek:
Not a problem if you are the only one working in there, but if anyone you care about, with less upper body strength than yourself, uses any compressed air, you may want to exercise great care in choosing your couplers.
Edit: thank you all, yes, next time I'll get a closer view, just over 40, not 400. :eek: :eek:
Still looks like the author is having difficulty.
Leveleer
Superior/Duluth
The Milton V is rated up to 300 PSI.
Anyone brave enough and or strong enough to attempt to connect it at the rated pressure?
If so, I'll make sure I'm at a safe distance before you attempt to disconnect it.
I have some Milton V knock offs I bought at Menards that are much easier to connect. No doubt because they are rated at a much lower (more realistic pressure)
WVBrady
WV
Yep, on my bigger monitor, there is clearly two digits after a decimal.
On my netbook and phone it really looked like a WTF!!
Yeah, otherwise the guy might be a contestant in the World's Strongest Man contest. :D
Nexussian
Alaska
Thanks, couldn't see that, edited earlier post to reflect that; after 1/2 dozen attempts. :confused: :wtf:
Leveleer
Superior/Duluth
I was curious as to why the Menards high flow coupling was so much easier to connect then the Milton V so I disassembled both to determine the cause.
My conclusion is that the Menards version is a significant improvement in design.
The Menards version is a one piece poppet and the Milton is not and as a result the Milton has an effective aperture that is much larger due to a much larger o-ring.
The Milton also has a tendency for the poppet to shift off center causing leakage.
Milton V style poppet on the left in the photo.
Trey T
Houston, TX
can you link the Menards high flow coupler? How does it perform and how long have you had it?
Leveleer
Superior/Duluth
Oddly I can not find them online. I'll go by the local Menards and try and find out why they aren't online.
I have been using them for about 9 months to a year and never had a problem.
They appear to be very well made.
scooby074
Nova Scotia
You found the reason many professionals dont use cheap fittings.
Try these and thank me later.
https://www.fastenal.com/products/details/0400426
Those swing couplers are the best coupler Ive ever used.
A former employer went on a massive pneumatic safety kick (safety release couplers, 3way dump valves for larger airlines etc) and bought these exact couplers. Almost like a swiss watch for quality. I know they didnt pay $40 ea, but they were "expensive" or so we were told.
Ive used Miltons, including their Provost knockoffs (which **** btw, they start leaking in no time, even using genuine Milton plugs) and the Oetiker are the nicest.
Also for anyone having strength issues, they are very easy to hook up too.
Just found a video showing them in detail, including the method of coupling
Leveleer
Superior/Duluth
Back to the Milton V couplers, If one were to use it at the rated pressure of 300 PSI, it would take just about 100 pounds of force to connect it and probably significantly more to disconnect it assuming it would even be possible. If you did manage to disconnect it you would be wise to wear protective gear like a flak jacket and very good hearing protection to say the least.:scared:
Leveleer
Superior/Duluth
Here is a video I shot of my force testing of the Masterforce brand high flow coupler which I find superior to the Milton V.
It's significantly easier to connect and disconnect then the Milton V.
MJockey
Maryville, TN
Will this coupler work with standard industrial (Milton M) plugs also?
Jeepster04
Ive had that Oring on my Milton become dislodged. It slightly cut the oring and I think I couldve just reset it but I bent the housing in my vice...
Leveleer
Superior/Duluth
That is not surprising to me at all. I have had the poppet o-ring come partially out of the groove and cause a massive blast of air directly at me that I couldn't stop without turning the supply valve off. This happened more then once.
The Milton V 1/4 coupler is a terrible design!
Highly un-recommended by me!
I'm thinking about making a video explaining it in detail.
Leveleer
Superior/Duluth
This is one of my Milton V couplers that jammed and leaked constantly.
If anyone is interested, I will make a video showing why the Milton V is a horrible design.
