Milwaukee 18v saw issues...
Jason280
I have a Milwaukee 18v circular saw, model # 2830-20. I went to use it a few days ago, the blade will start spinning, but almost immediately stop. It won't turn long enough to get up to speed, and I initially thought it might be the battery...except I've tried 3x others and its still doing the same thing.
It *might* still be under warranty, have to email Milwaukee, just curious if this is a common issue with the saws.
teknikfrog
My M18 saw was just in the shop for intermittent failure and they replaced the trigger.
goblue1998
Washington Michigan
I had the same problem and fixed it a couple of weeks ago by changing the switch.
Mine was the 7-1/4 fuel.
At the time, these guys were the cheapest.
jhendric
I had similar on my circular saw and my impact driver. It did what yours is doing for a bit, then stopped spring altogether. bot fixed under warranty both the trigger.
sparky 1971
Central Iowa
I'm a Milwaukee fan boy but will admit the triggers are not the greatest quality. I've sent in a M12 bandsaw, M18 impact driver, and a SuperHawg for trigger replacement. I've had other failures out of warranty, but tossed 'em in the trash and bought new.
J
Jason280
I'm going to call Milwaukee tomorrow and see if its still under warranty...maybe I will get lucky. If not, I'll try a replacement trigger.
