Milwaukee 3/4 inch Masonry Hammer Bit
AffableCurmudgeon
Triad Area NC
Is this a good drill bit to drill 8 holes in my concrete floor? Need to secure a 4-post lift. Just want to get something locally and not order it from Amazon.
Thanks.
dscheidt
Drilling 3/4 x 4" holes in concrete with a hammer drill will ****. Rent (or, heck, it's garage journal, buy) an SDS drill and the correct bit. It would take less time for me to drive to HD, rent the drill, drill 8 holes, and return it than it would to drill them with a regular hammer drill.
sparky 1971
Central Iowa
Beat me to it.
Damn I was thinking that too but I didn't want to post it first. I'm not an expert at drilling in concrete but I'd sure go to SDS or my rota hammer before a hammer drill for something that big and deep.
housewolf
East Texas
Yeah, 3/4” holes are no joke. You can do it with the smaller SDS rotary hammers but if you’re renting I’d go SDS max. The last 12 holes I drilled (out of a gazillion) were 3/4” setting my lift and the Bosch bulldog I used was pretty tired by the time we were done. Count on hitting some rebar along the way too
msharley
Central Pennsylvania
I rented an SDS Max from Home Depot. They also provided a 3/4 inch bit with the rental. It took less than 2 minutes per hole to drill.
Thanks for the good advice @housewolf , @RTM , @sparky 1971 and @dscheidt . It took longer to pond in the inserts and torque the bolts than it did to drill the holes.
That's great!
I have a Hilti.....makes short work of holes....
sparky 1971
Central Iowa
That's good. If you hadn't rented and stayed with the original plan of using a hammer drill, you'd still be drilling and may have burned up the drill.
428PI
Peabody, KS
I bought a HF sds max with their set of bits. Have only used the 1/2 bit so far but goes through concrete like butter. Not sure on rebar.
