Milwaukee 6117 Corded Grinder Electrical Problem
germanwrenchguy
Berlin, BE
So I picked up this corded Milwaukee grinder with a broken bearing which I replaced.
After putting it back together, it won't spin.
It's making a humming noise and starts to smoke lightly when left on for more than a few seconds.
I can't spot anything that's obviously wrong.
Both Field Coils measure about 3 Ohms, no short, armature is not shorted either.
And it did spin before I disassembled it. I must be missing something.
PCustoms
VT
yes it does. Cant spin it by hand when it hums though. I replaced the bearings, it spins as freely as it should
Did you remove any wires during the rebuild?
Did it spin up under power with the bad bearings? Previous owner may have burned the motor up if it was seized....
G
germanwrenchguy
Berlin, BE
I did remove the brush wires and the power cord.
Only thing I have put on incorrectly would be the power chord, but I already tried switching it around.
Since its A/C I wouldn't know the difference it would make anyways.
PCustoms
VT
What did it do before you change the bearing? It was probably toast and you just put new bearings in a dead grinder...
Can I just remove the PCB and try to wire it directly to power? Or does the PCB more than just regulating speed?
I certainly wouldn't, not sure what the PCB does
G
germanwrenchguy
Berlin, BE
it ran, sounded like low power and made a hell of a noise from that one bearing.
now its just spins way nicer on hand, but won't start spinning on power.
PCustoms
VT
If your confident in your mechanical assembly I would find a wiring diagram and verify it's correct.
tarbellb
Oregon
very likely it was torched before
Don't worry, Milwaukee corded grinders **** *** even new
American Locomotive
Rhode Island
I've seen this happen on brushed power tools before. Something is assembled incorrectly. When you turn the tool on, it the rotor gets yanked into the stator laminations and can no longer spin.
