Milwaukee 9.0ah battery not charging
Jason280
I have a Milwaukee 18v 9.0ah battery that will no longer take charge. It was showing one bar on the charge indicator, but no matter which charger I tried, would always show green when placed on a charger. Now its to the point the bar is flashing red (meaning the battery is essentially dead), and still only shows green on a charger.
Is this likely a dead cell and no chance it will charge, or something else? Anything else to try to get it to charge? Not sure if its still under warranty, may need to check tomorrow with Milwaukee.
Jsf721
LI, NY
I have had luck reviving them with the older HD chargers. Newer ones require too much voltage to be seen
allinon72
Indianapolis
When this happens to me and I can't revive it by jumping it with another battery, I just go ahead and send it in.
J
Jason280
Not sure if I have one of the older style chargers or not, how are they different?
J
Jason280
Yes, positive to positive negative to negative.
I may need some more details here. How long are you jumping them for? Are you simply jumping them, together for a period of time, and then throwing it on a charger?
allinon72
Indianapolis
30-60 seconds, just enough to give the cells a jolt so the charger recognizes the battery.
GaryM909
Calgary, Alberta, Canada
I have a Dewalt 9 ah battery that wouldn't charge about a month ago. After I kept trying for a couple weeks I put it in my leaf blower and ran it until it was fully drained. I then put it back in the charger and it charged right up.
dnschmidt
Phoenix, AZ
This is at least a 5 year old battery and 1) is no longer made 2) is out of warrantee (3 years). Secondly, this was a notoriously bad battery, true not as bad at the old 12.0 or 8.0, but the fact is it's time to go to the Home Depot and throw it into the battery recycling bin.
Beerhippie
Far NE Oregon
Oddly, I was in the process of salvaging the good cells from some old Mildew batteries I retired a few years back as they'd no longer take a charge. I kept finding the most, and sometimes all, of the cells tested out and charged just fine by themselves and stuck a couple of the old battery packs into the red charger... they're now back in rotation!
I haven't seen any YouTube vids about letting dead batteries sit around for few years to revive them....
J
Jason280
Tried jumping it with another battery, no luck. It would actually read a charge, but quickly die off when actually using...either way, not matter which charger I tried, it still lights on "green" (charged).
tak1313
It may be one (or more) individual cell(s) are marginal/bad and causing the logic circuit in the battery/charger to see a high resistance and think the whole pack is charged. The high resistance would make the charger think everything is all charged up when it's not. It could also be a bad resistor or capacitor in the circuit (of the battery).
cgrutt
Probably a bad cell you can open it up and measure voltages individually. Bad cell will probably show some signs such as swelling, etc. in addition to having lower (or no) charge. I have a few packs I've been meaning to open up and replace cells. I'm planning to replace all of the cells not just the bad ones. I ordered the replacement cells online they were fairly inexpensive and are same type used by Milwaukee. The cells in my pack were made by Samsung not sure if that changes or not.
