Nezil
Milwaukee "Compact" 3/8 M12 Fuel Ratchet
As is typical when I set about buying a new tool, I turn to forums and social media to influence my decision and do some background reading.
I'd ended up getting an M12 Fuel 3/8 stubby impact wrench recently and managed to get it at a bargain price with three batteries (CP 2.0, XC 4.0 and XC 6.0). With these spare batteries, I fancied adding to my M12 tool collection with a ratchet, and so started the research.
Reading and watching reviews, the general consensus seemed to be that the newer fuel models were a significant improvement in terms of strength (for manual ratcheting), power, build quality, run time etc. There are also extended reach models released even more recently, but at a price premium over the already expensive fuel models.
Most of my sockets are 3/8. I do have a full set of 1/4" drive as well, but 3/8 is kind of my go to size, so initially I picked up the 3/8 Fuel ratchet.... Damn that thing is heavy, and the head is MASSIVE... It's got a ton of power (55 ft-lbs), perhaps too much power, but the size and weight just killed it for me.
The original (non-fuel) models feel a bit flimsy in comparison, but the size and weight are so much better. I nearly went this direction, but inspired by a YouTube video that I can no longer find, I took a different path.
I picked up a 1/4" Fuel ratchet, and modified it to have a 3/8" anvil:
The 1/4" Fuel ratchet is similar in size and weight to the original 1/4" and 3/8" units, but is better built, slightly more powerful, brushless.
Here are the specs for comparison:
1/4" Non Fuel
- 10 3/4" / 27.3cm long
- 1.9 lb / 860g
- 30 ft-lb
- 250 rpm
3/8" Non Fuel
- 1.9 lb / 860g
- 35 ft-lb
- 250 rpm
1/4" Fuel
- 10.39" / 26.4cm long
- 1.93 lb / 880g
- 40 ft-lb
- 250 rpm
3/8" Fuel
- 10.87" / 27.6cm long
- 2.43 lb / 1,102g
- 55 ft-lb
- 250 rpm
As I said, the 3/8" Fuel is a beast, both in terms of power and it's just huge. What I wanted was a 3/8" model with the size and features of the 1/4" Fuel... here is how I did it.
1/4" Non Fuel
- 1.9 lb / 860g
- 30 ft-lb
- 250 rpm
3/8" Non Fuel
- 1.9 lb / 860g
- 35 ft-lb
- 250 rpm
1/4" Fuel
- 1.93 lb / 880g
- 40 ft-lb
- 250 rpm
3/8" Fuel
- 2.43 lb / 1,102g
- 55 ft-lb
- 250 rpm
