flippin
With Black Friday around the corner, I am at a purchasing crossroad. Curious to hear your thoughts and rationale. I will be purchasing a few new Milwaukee Fuel tools and I am having trouble deciding between hex impact versus impact wrench.
So far I have decided to purchase;
(1) Milwaukee 2762-22 M18 FUEL™ 1/2" High Torque Impact Wrench w/ Pin Detent. This of course will handle all of the heavy duty hi-torque situations.
I will also be purchasing both an M18 impact driver and an M12 impact driver but can't decide between;
M18 Fuel 3/8" impact wrench (friction ring) or
M18 Fuel 1/4" hex impact
and
M12 Fuel 1/4" impact wrench (friction ring) or
M12 Fuel 1/4" hex impact.
Clearly there are adapters to go from one to the other so it will be easy enough to switch back and forth. However if you were starting fresh which would you want to begin with. Is there a torque limitation to the ever popular 1/4" hex format? I want both the M18 and M12 because there will be situations when the higher torque of M18 will be required and conversely the M12 compact size will be advantageous. I work primarily rigging tournament boats and the M12 power will probably be sufficient however much like many of us our tools will be used in a variety of different situations.
Lastly given that there will be an investment made in both formats (M18 & M12) should I consider the M12 cordless 3/8" ratchet. Certainly interested in hearing your comments on this tool. Pardon my ignorance as I am not a licensed mechanic but when driving conventional nuts and bolts is it ever bad to use impact vs just a cordless ratchet?
Many thanks in advance for your thoughts.
and
