Overall I've been very happy with my Milwaukee M12 and M18 tools. The one tool that I continue to struggle with, however, is the M12 rotary tool. Right after I first purchased this tool it would randomly not turn on. When the switch was flipped all four lights would flash. This wasn't a battery issue as the battery worked fine in my other M12 tools. I used Milwaukee's online process and sent it in for evaluation. It worked when I received it back, but it still shuts down and all four lights blink with the slightest amount of pressure. It's to the point where the tool is almost not worth using. I don't use it for heavy die grinder type work. It's mainly used to clean up atv engine fins, or aluminum atv hub crevices with small wire brushes.
Has this been everyone else's experience with this tool, or is it likely that mine is still defective? I can send it back in to Milwaukee again, but I'd like to hear how the tool has worked for others. If everyone has had similar experiences I may have to try another brand.
