I have the M12 Milwaukee system and one M18 tool. I‘m thinking of buying a nailer for small projects such as frames, shelving, etc. What size and tool should I start out with? I am not familiar with nail gauges etc, just an older woman who wants to do a few projects around the house and needs something easy to use and reliable. The Palm nailer is on sale at my Home Depot for $99. Is that a good starting one? Or can someone recommend a good versatile model to start with? Thanks!
I have a couple you might like. The 18ga narrow crown stapler is probably my favorite. Reason, it draws parts together like a headed nail or almost like a screw. This can save clamping etc. That would be my advice.
MILWAUKEE® M18 FUEL™ 18ga ¼” Narrow Crown Stapler delivers consistent unmatched performance without a compressor. This cordless stapler also has tool-free depth adjustment
www.milwaukeetool.com
The downside of this tool is that it leaves a little 1/4” long divot in your project that really should be filled. If you don’t want that, the 18ga Brad nailer would be the better choice.
MILWAUKEE® M18 FUEL™ 18 Gauge Brad Nailer makes clean, consistent nail holes, is compact in size with zero ramp-up time. The cordless brad nailer operates using REDLITHIUM™ Batteries
Don’t let the name fool you. Brad nails are strong connectors. The nails I bought have grooves under their almost imperceptible heads like ring shank nails making them tough to remove. There are a wide range of sizes available and the Milwaukee gun shoots many of them. The heads are so small, you usually don’t need to fill them.
Downside of the Brad nailer is that you won’t get good pull up so you really should clamp. Also, I think most people use these in concert with glue like titebond. Titebond is slippery. If you don’t hit these nails in at the right angle, they can actually pull your pieces out of alignment.
I think the stapler is a little easier to use, makes stronger joints, but leaves a little more finishing work.
