Milwaukee Power Tools Deal Permathread
Crabman
Alexandria, VA/Dameron, MD
ebay search was wide indeed
Here is narrowed to M18
and M12
2manytools
Mt Pleasant, MI
Three 5.0ah M18 batteries and charger for $199 looks enticing.
That goes on for the next 2 months. It was also cheaper by $20 yesterday. Also not so hot if you keep the 3rd battery.
If you need batteries, you need to make sure you get the "free" battery as a separate SKU. So you can buy 2 kits (and 2 free batteries that you return), so in the end you have 4 batteries & 2 chargers for $199
BroncoAZ
This M18 12.0 and pair of 3.0 batteries for $222 plus tax is as good as I’ve seen. I don’t really need the 3.0 batteries. There are also numerous small sellers on eBay with the 12.0 for $151, also cheap but I’m suspect of authenticity being a no name seller.
Crazyjake8493
Upstate NY
The chainsaw really does need the HO batteries. When I ran my 12.0 down, I tried a 9.0 and it went into over heat protection SUPER fast, less than 5 min of use. I swapped to my 6.0 and was able to finish all the remaining cuts and the thing was fine. The 9.0 really is the ******* child of the bunch.
You might have an issue with your 9ah. I use mine regularly with a 12ah and the 9ah while the 12ah is charging. It goes for a lot longer than 5 minutes. I felled and cut up a good size tree a few weeks ago on just the 9ah.
MAYBEN
Sparta, NJ
The shop vac plus tower light plus 2x 6.0 batteries for 350 seems like a great deal to me?
I must’ve missed, showing $440 for me
mikeinri
and M12
THANK YOU!!!
Mike
Crabman
Jarhead0408
Who knows?
ebay has a 20% off sale on a bunch of stuff. I got an m18 brush cutter attachment which I don't see on sale much.
Here is the Milwaukee stuff
Thanks man. I’ll be picking that same attachment up.
LopezBart
Lopez Island, WA
I have a growing stand of phragmites, which are an invasive reed type plant.
They laugh at weed whackers, so going to try to up my game with the brush cutter.
Phragmites
I've had excellent luck w/ my M18 Sawzall and a Diablo carbide pruning blade in dealing with Ocean Spray (also known as hardtack). Easier and a lot safer than a chain saw. Have you considered fire or goats? From Wikipedia:
Phragmites australis subsp. australis is causing serious problems for many other North American hydrophyte wetland plants, including the native P. australis subsp. americanus. Gallic acid released by phragmites is degraded by ultraviolet light to produce mesoxalic acid, effectively hitting susceptible plants and seedlings with two harmful toxins.[4][12] Phragmites is so difficult to control that one of the most effective methods of eradicating the plant is to burn it over 2–3 seasons. The roots grow so deep and strong that one burn is not enough.[13] Ongoing research suggests that goats could be effectively used to control the species.[14]
pbon
I've been searching for a deal on the dual battery M18 shop vac - has anyone seen anything?
I have seen $75 off $300 and $100 off $400 but don’t know if the vacuum was eligible. I bought one earlier this year using a $75 off $300 deal. The vac was $299 so I bought a marker for $2 to break $300.
tmshort
Central IN
Just found this:
15% coupon for BF
A&P mechanic
FL
Where did you find the $100 off $400?
I am looking for a deal on the 106" guide rail P/N 48-08-0572 and the clamps for the M18 fuel track saw but not many places carry the long guide rail.
I called ToolUp since they are offering the $75 off $300 but the salesman said explained they do not special order Milwaukee items if it they not on their website. Thank you.
pbon
Tool Nut and Red Tool Store but the discount may be for just some full price items
A&P mechanic
FL
Thank you for the coupon codes, Tool Nut and Red Tool Store do not sell the longer 106 inch guide rail. I will keep an eye out on Cyber Monday but may just get the long guide rail from HD.
If anybody decides to get a track saw today, I ordered the M18 track saw today for 352 shipped (399-75 off coupon + tax) from tool up. It will ship around 5 weeks from now. This was the cheapest I found for the bare tool.
(I do not need anymore batteries and may not use the shorter track, so I went with the bare tool. I will get the longer track eventually. I have the M18 7 1/4 inch circular saw currently set up on (2) 55" aftermarket tracks using a sled. If the Allen screws that connect the tracks together are tightened to much or the gap is to far, the saw gets stuck on the track at halfway point. So, IMO the longer 106 inch track is the way to go instead of the (2) shorter pieces to cut a 4x8. Thank you again for the code.
Frenchy
Twin Cities, MN
Hi all,
Anyone see any better deals for the M12 grease gun than the $169.00 option at HD with the one battery pack? I know it was cheaper over Veterans Day weekend but missed out on that deal.
Any deals on the new gen battery packs? Not that I really need them but would give them a try if a deal could be had.
Thanks!
mngundog
MN, in the sticks, U.S.A.
Hi all,
Thanks!
As posted above me, $129 today
ShadowRuleZ
Detroit
Someone SD posted a combination M12 grease gun and 1/4 fuel ratchet w/charger and two batteries and free tool that you can return ("hack") that will put the total for the grease fun and ratchet to $183. I'll probably get a few more bucks selling the charger/batteries which will drop the price a bit more for the two of them.
06 DIESEL
Middle River, MD
If you have M12 batteries already you can add the grease gun as your free tool and get it by itself for $112.67
Odd-job
Thank you. Got me.
It wouldn't let me split the order (kept on getting a technical error) between store and pickup so I could just abandon one item more easily.
2manytools
Mt Pleasant, MI
Thank you. Got me.
It won't let you split promo items at all, but you can choose different stores to pick up from. I don't know why, but I find this a better way to go if I don't plan on getting a portion of it. Usually you can can cancel within 45min, and still get the promotional pricing
oops
Home Depot M12 new and repeats in Pro Special Buy of the Week--ends Sunday (5 days):
Main deal page for other items
Rusty67
LA, CA
If you scroll way down, you'll see some shop vac deals including the first time I've seen a deal on the dual battery unit. Not the deal I'm looking for to jump on a dual battery shop vac but interesting to see it on sale for once.
oops
Home Depot M12. A few deals that look like they are hackable and a few I overlooked.
Three that look hackable, you mileage may vary:
Polisher/Sander w/ CP2.5 is still around for $149
Expires Sunday
On the Weekly Buy page two posts up there is also:
3/8 NON-high-speed ratchet w/XC4.0 and charger $165 (unless you are looking at team yellow--Thank you, I'll see myself out...)
Right angle die grinder with XC4.0 $165 vs the $199 w/CP2.5 and XC5.0, if you a full up on batteries
Small rotary tool (dremel thing), tool only, no batts $79
Or, on Weekly Buy page: With CP2.0 and charger $100
You know you need a spare while the other one is out for wty replacement
And a Dremel 4486 keyless chuck (~10)
bigboost
Jacksonville, Florida
Picked up my 2nd 3/8 stubby impact yesterday, for what its worth fellow garagers, it's one of my most used tools. It's just as strong as my M18 3/8 full size impact and fits in way more places.
