paulsomlo
I recently got a like new milwaukee D-handle drill with the right angle attachment off of ebay.
I'm trying to remove the chuck from the right angle attachment so that I can change the speed, but it's giving me hell.
I removed the LH screw that retains the chuck, but now I need a sanity check; the chuck IS RH thread, yes? The stud on the end of the drill is RH, the chuck on my 1/2" hole shooter is RH, and the Milwaukee user's manual doesn't say anything to the contrary.
I've tried chucking a large allen key, holding the hex on the right angle attachment with an open end wrench, even using steel shims to take up the slop on the wrench to keep it from rounding over the hex on the right angle attachment. I've also tried chucking a large hex bit and using my IR mid-torque impact, no good. I tried two steel flats bearing on the nut, held in place with my shop press, a hardened steel bar where the chuck key goes, and a deadblow hammer, no good.
I've tried some Kroil, but I'm doubtful - this thing is pristine, doesn't have any corrosion on it.
If anybody's got some brilliance, send it along please. I'm about out of answers.
