Tarheel Slim
Im at the point where in ready to insulate my 30 x 44 pole barn,i have white EPS foam tapped up with red tape in between the perlins and now i would like to add insulation,im using 2x4 for framing in between the posts ,im wondering if i use insulation made for 2x6 framing if that would be better than having a gap between the EPS and the backside of the insulation.Does the insulation have to be tight against the EPS foam ? If i use regular 3.5 inch glass insulation made for 2x4 framing would that be ok too?Also thinking of using 24 inch spacing for the insulation although im not sure what i will choose at this point,i had Roxul insulation in my last shop it worked great but i dont have the connection to buy it cheaply anymore so i need some input please guys,
thanks.
thanks.
