Mini Calking Gun For 5 fl. oz Tubes ?
427HISS
I bought some tubes of RTV silicone sealant, and I'm wondering if there is a small gun for these 5.5"-6" tubes ?
rlitman
Long Island
Ah. I've never seen a cylindrical tube in that size. So would this work in a regular 10oz caulk gun, with a bunch of wasted space in the back? And that's basically just a regular caulk gun, with a shorter barrel? Or is this a different diameter too?
davethorik
Norka, Ohio
The Permatex tubes look to be 2" diameter, same as standard 10oz. tubes, so I don't see why not.
427HISS
Dave, what did you use the "Right Stuff" on ?
I'm building a engineand checked outtheir video on youtube and looked great. Buton a engine forum most guys saidif you want a perment fix, ok but if you want to remove that part, it may distroy it. A couple said they bent their valve cover and timing cover trying to remove them. One broke a end off his intake manifold. eek !
I hate it when sellers on ebay advertise a product for a lower price of a product to get you to look, then the shiping is 2-3 times higher !
So, check out his cost and shipping amount. :eyecrazy:
https://www.ebay.com/itm/Permatex-S...022180&hash=item4648dfe3e3:g:fukAAOSwldRaAm2O
davethorik
Norka, Ohio
It's been a while but I believe I used it to seal a diff cover on an axle on my old GMC pickup. It came as part of a kit with 2 or 3 tubes and the gun, I bought it at cost when I used to work at Carquest.
427HISS
I bought the smaller tube to try out in building my newest engine, so I was courious if there was a small gun rather than the normal longer cumbersome size. I'm sure it will aid in laying down a better, smoother and consistant bead of silicone on larger parts like oil pans, but also on most other parts.
