Mini "crash kit" contents
IndyGarage
Indy
About a year ago, I created a "crash kit" for my home. I'm always fixing things: from the appliances, to the furnace, to the cars or whatever. I do probably 1-2 small fixit jobs a day and on the weekend maybe 10 of them.
I'd say about 80% of the time I have to take the tools to the project rather than bringing the project to the tools. I found myself making constant trips back to my garage to bring in more tools.
So I took all my most used tools and supplies, and put them in a rolling cart that can be rolled to the fix. It had to be small enough to fit in the trunk of the car, and light enough to pick up or take up stairs.
That has worked out very well. I'd say I can do the average project about 30% faster. For big projects, I still have to bring more stuff, but even then those items only supplement the basic kit. After about six months I redid the box and took some stuff I hadn't used out, and put some other stuff in.
So now I'm ready for phase 2. I'm putting together a "mini crash kit" which will be intended for carrying to the initial evaluation of the problem - even before I would retrieve the crash kit - like as soon as my wife says "the dryer isn't heating".
This will be a much more portable kit, and have only the bare essentials for fixing a lot of things. I would also throw it in the car with me. My goal is to keep it under 5 pounds and fit into a handbag sized nylon tool bag I have.
So far the contents are:
1. Stanley 25 pc 1/4 inch socket set in blow molded case - I find that I use 1/4 inch sockets all the time on projects - especially in the 8,10,12 mm sizes and the 1/4, 3/8, 5/16, 1/2 sizes.
2. Heavy "medical" type scissors/shears - I use these all the time to get overpackaged items out of the box.
3. Surefire G-2 LED light, plus extra batteries - almost every project needs light.
4. 4-way screwdriver
5. Small 12 foot tape measure
6. Fuller slip joint pliers
7. 6 inch and 8 inch adjustable wrenches
8. Leatherman - I've currently got a skeletool in there.
9. Clamptite tool and about 10 feet of wire - great tool for creating wire clamps.
10 small bag of various zip ties.
11. Caribiner
12. Cool little bit driver ratchet I found, and a bunch of bits.
13. Nite Ize flashing safety light - Little reflective LED strip light I found. You can hang it to the back of your car, or your belt loop if you have to work in traffic, and drivers will see you.
14. Nite Ize Figure 9 rope tightener and 10 feet of rope - I love the Nite ize stuff.
15. Emergency poncho - fits in a 3" x 4" thin pouch
16. Foam ear plugs - 2 pairs.
That's what I've got in there now. There are many other things I'd like to have, but the weight adds up pretty quick. I just want a kit that will fix maybe 30% of the jobs I come across immediately.
Does anybody else have a mini kit like this? What do you carry?
A couple Items I'm thinking about putting in there:
Swap out the skeletool for a Leatherman crunch tool.
8 inch pair of Knipex cobras.
Superglue.
Comments?
I
IndyGarage
Indy
BFH is one of my favorite tools, but it won't fit, and to be a BFH, by definition it's heavy.
Anyway, one of the most effective uses of an adjustable wrench is as a hammer. Small prybar/nail puller might be a good idea.
Danglerb
SoCal
Some kind of meter or at least a test light.
Small pry bar.
Lose the blow molded case for the sockets, put them on a strip, with ratchets and extensions loose in the bag.
Couple jumper wires with insulated clips.
Small hammer.
Head band light.
Bic lighter
Heat shrink tubing.
2' of aquarium type plastic tubing. (listening, blowing, draining)
Cheap leather gloves.
Bandaids and disinfectant wipes. (so you don't bleed on stuff).
Bottle of water and a snack bar.
Empty zip lock bags.
Cell phone with a camera.
Inspection mirror.
Pickup magnet.
Small notepad and working pen.
Duct tape on a small diameter hub, a few feet.
mrb
just a couple things off the top of my head
roll of 3m 33+ electrical tape
crimper / stripper / cutter tool Klein #1000 is a good one
small bag of some crimp terminals and a couple wire nuts
'tic tracer' type non contact voltage detector
box or two of procell AA batteries
I
IndyGarage
Indy
Thanks everyone for the suggestions - some good ones so far.
Some kind of meter or at least a test light. Yeah, I have a very small meter that might go in there.
Small pry bar. I'll take a look next time I'm at the store for something small with a nail puller.
Lose the blow molded case for the sockets, put them on a strip, with ratchets and extensions loose in the bag. Nope, I love the blow mold cases - That's my favorite thing about my SK sets - I can instantly see if I've left anything behind.
Couple jumper wires with insulated clips. If I have the meter, I'll just use the leads as a jumper.
Small hammer. I'm seriously thinking I could weld a hammer head onto my adjustable wrench
Head band light. Good idea
Bic lighter I don't think I've ever used one, except for the kids birthday parties. I suppose a bic would shrink heat tubing...
Heat shrink tubing. Couple pieces, but I wouldn't be able to carry enough variety to handle too many jobs.
2' of aquarium type plastic tubing. (listening, blowing, draining) Rare for me to use it
Cheap leather gloves. Good add, but a little bulky. Nitriles also might be good
Bandaids and disinfectant wipes. (so you don't bleed on stuff). No, I just bleed till I can get to the first aid kit.
Bottle of water and a snack bar. Not for this kit - this is simply the "first 10 minutes, maybe I don't have to go get tools" box.
Empty zip lock bags. I have the zip ties in a bag. If I need one I'll dump them and use the bag
Cell phone with a camera. Normally have one in my pocket, but I don't remember to use the camera often enough
Inspection mirror. Good Idea
Pickup magnet. I never drop things... yeah right
Small notepad and working pen. Mechanical pencil might be better
Duct tape on a small diameter hub, a few feet. I use duct tape, occasionally, but not near as often as some folks, so I'll leave it in the other box
Nuts and bolts are a good idea, but there is such a variety, that I would rarely have the right one.
I
IndyGarage
Indy
Agree with Danglerb's additions to the kit.
If you want to get obsessive/compulsive over your kit, I have the place for you:
http://edcforums.com/forum.php
see in particular this thread
http://edcforums.com/showthread.php/42616-The-heart-of-EDC
I went to the forum and tried to figure out what EDC stands for, but couldn't find it quickly. It seems more geared toward survivalist kind of stuff.
This kit is for tools to fix things - don't need a gun in it - although there are times when I feel like shooting things when they break...
I
IndyGarage
Indy
OK, figured out that EDC means every day carry - dumb me for not knowing the latest TLA's.
mrb
oh and a sharpie industrial marker, extra fine point
Danglerb
SoCal
Sharpie instead of a pen or pencil, writes on everything, including paper and zip lock bags.
Zip locks I would use for all the smaller items, nuts, bolts, washers, lock washers, then dump stuff together as I needed to use a bag.
Main thing for me on that first look is gathering information. Complete model number of the motor I need to replace, accurate size of a missing bolt, dimensions of something I need to build or fit something to. I'm not much of a first visit fixer. ;)
I
IndyGarage
Indy
So I made a pass at lowes and found a 10 inch stanley prybar that has a small hammer head on it. Also got a headlamp, and a utility knife and a small pair of kobalt slip joint pliers that work similar to Knipex - thought I would try them out.
Thanks for all the ideas
p_mori7
Montreal, QC., Canada
When I was a younger unattached gentleman (ahem)...my crash kit consited of:
1 pair of clean underwear
1 pair of clean jeans
1 pair of clean socks
1 clean tee shirt
1 toothbrush
1 comb
1 small tube of hair gel
1 razor
1 pack of 3 condoms
hehehe
