Mini garage- 10x12 shed build
ranger_dood
Pennsylvania
Well, it's not a garage, but hopefully it can live here...
This build started out because I need a place to store all my lawn equipment. Push mower, string trimmer, rakes, and such. Currently, all this stuff is on my back porch. It's cluttered, and the porch needs some work. By work, I mean... it needs to be torn off and rebuilt. So, everything needs to find a new home. Enter, the shed!
My brother has been instrumental in this build... I am not actually all that handy when it comes to building stuff from scratch. He planned this all on the fly and I just followed his instructions. Anyway, on to the pics.
First off, I had to dig out a high spot in the yard. My yard is... all over the place. There's high spots, low spots, and a large ridge that runs along the back fence line. I moved some sod around to try to level it out, and we planned on putting the shed in front of the ridge...
Then came the 2b. We ended up with 3 skid-steer scoops to get everything leveled and to a sufficient depth all around. Tamped it down to make sure it wasn't going to go anywhere-
That night, we made our first run to Home Depot for the bulk of the supplies. Of course, it was the first of about a half-dozen trips to Home Depot -
First day of building. 4x4 base with 2x6 floor joists on 16" centers -
Got the subfloor down -
2x4 walls 16" on center. The missing studs are where the windows will go -
Started the T1-11 sheeting. Amazing how sturdy the frame gets as you do this -
Finished the sheeting and figuring out the ridge line for the roof -
Got two of the windows in and the roof rafters put in place. A note on the windows- I'd been buying everything from Home Depot, because of all the credit financing deals. The two windows in this picture were the cheapest that HD had, and they were $75 each for Anderson sliders. I later found that Lowes has cheap single pane sliders (with screens) for $38 each. Lesson learned. The second picture is a bonus that I took while my phone was vibrating. Wavy fun times! -
Kind of skipped some pictures here. We got the roof decking down and tar papered one day, and put shingles on the next. They're architectural shingles that match the house. -
Looks like a real shed...
Today, we built some doors. 2x4 construction, total door opening is 4ft wide. Using piano hinges, because that seemed like the best option. The hinges are attached to the trim, which is 2x3's, glued and screwed on both the shed and the door. Unfortunately due to a miscut on the miter saw, we ended up short a piece. -
And that's where we stand now. We still need to close in the ends and do all the finish work, as well as build a ramp.
In addition to yard stuff storage this will also be acting as a motorcycle garage. My project bike is sitting under the carport, partially exposed to weather. It'll be nice to have a protected place to store and work on it. I'm also looking forward to building a work bench, and essentially turning this into the garage that I don't have room for.
Any questions, feel free to ask!
redyute
southern md
Sweet I need to build me one so I can store my stuff when I do my garage rebuild. How much did the material run you if you don't mind me asking
R
ranger_dood
Pennsylvania
As of right now, I'm just over $2000 including the stone. It's more than I budgeted for, but it's built to a much higher spec than any of the pre-built or kits that I've looked at. It doesn't include any new tools (the only thing I had to buy was a tamper), but it does include two new saw blades and a pair of gloves, which I would consider consumable considering how many cuts were made in the course of the build.
I shouldn't need too much more to finish it out. Just some trim, primer, and paint.
captain14
Good looking build so far. You can't win all the price wars especially when you are using someone else labor (brother). Sorry about the windows but was the quality the same?
Gotta watch the stuff you put into the shed, your size fills up fast. Are you runnin electric out there?
R
ranger_dood
Pennsylvania
By specs alone, the Anderson windows should be a "better" window. They're double pane and low E. However, when locked the windows are loose in the frame. I can slide the whole thing back and forth probably 1/4". I wouldn't put them in my house, for sure, and they're the more expensive ones!
The cheapos from Lowes are single pane and not coated for any kind of thermal efficiency. But, when locked, they're locked tight in the frame. They're by far the better choice for a shed, and at nearly half the cost. Had the first two Anderson's not been installed already, I would've returned them in favor of the cheapos.
Electric to the shed is not in the plans. I have a heavy-duty extension cord that I will drag over to an outlet on the back porch when needed. Eventually I may want to run power to it, but I need to upgrade my house service from 100a first.
R
ranger_dood
Pennsylvania
Small update, but we're getting closer... Closed in the ends and finished the trim on the door. Ready for paint, and I think I'm going to go with a barn look. Red barn paint for the T1-11, and white for the trim.
This is what we had left of a full sheet of T1-11 after closing in both ends.
Was also looking for cheap window treatments... Wound up with a few cheap vinyl blinds. I think they were $12 or $14 each
grissom
Looking Good :thumbup:
A few questions:
What is the height of the interior wall?
How far out are the overhangs?
What do you estimate it will cost?
Thanks
R
ranger_dood
Pennsylvania
A few questions:
Thanks
Grissom,
Interior walls are probably around 7'6". We used full 8' sheets of T1-11 for the siding, so subtract for bottom and top plates and some overhang at the bottom.
If I recall correctly, we ended up with a foot overhang on either end.
Materials cost was just north of $2000. Attached is a document in a ZIP file with the breakdown of materials cost. Had to ZIP it because the attachment size limit for a normal doc is only 19kb.
  • shed breadown doc.zip
R
ranger_dood
Pennsylvania
Okay, this should be the last update for a while. Did 3 days worth of painting to get the shed ready for winter... Didn't want to leave any exposed wood over the winter!
Just FYI - painting T1-11 with a roller and a brush is a pain in the ***. At the very least, you should have someone to help you. I didn't have that luxury.
Starting off. I had already painted the back, and gotten this far with one side. I think it was at this point that I stepped back and realized how much of a pain this was going to be.
End of day 1, coat 1. This took about 7 hours.
Here it is at the beginning of day 3. The 2nd coat of barn red was dry, as as good as it was going to get. 2nd coat only took 6 hours.
At the end of day 3. I primed all the trim and face boards with Kilz, and then painted with barn white paint. I used the Kilz because it had a 1 hour recoat/topcoat drying time, versus a full 8 hours for the Behr barn paint. Painting the trim and everything took a further 5 hours.
I like to compare end of day 3 with this picture before paint. Looks like a completely different shed...
Bonus picture of a bunch of **** in there. It looks like all the scrap wood will take up space on the left until next years campfire season. I also ended up with an extra sheet of T1-11, which kind of ***** because it was $35.
All 3 days of painting were done consecutively. Saturday/Sunday/Monday. I hope to not pick up a paint brush for a while...
Roan
Texas
ranger dood - ran across your post while researching Kilz Barn Paint. Your project was a great read, and thanks for all the pics. Well done. After almost 5 years, how's the barn paint holding up?
