Mini Lathe
dxdexter
I have had need many times to seek the services of machinists over the years, mostly for small items, and would now like to venture into this field and learn as I go.
I have only a cursory knowledge of machining and would like to purchase a bench top mini lathe. I know the standard answer for this forum is to buy USA and nothing else period, but all I have been able to find is offshore manufactured products. The prices range from $600 for a 7x12" up to $1200 for a 10"x18".
Much of what I have discovered, while researching, is that many of the hobbyists that produce miniature engines etc. use these offshore products. Does anyone have any experience with the smaller model lathes and could they recommend any in particular. Do they give accurate results out of the box or do they need tweaking?
Maybe I should be looking for used. Do domestic manufacturers produce these small units?
I do not have the room for a large lathe, nor the requirements.
wilbilt
NorCal
I have three of the old 1940s Craftsman/Dunlap 6x18 109.0703 lathes. To be honest, they are not the most capable machines out there. An Atlas-manufactured 101 series would be a better choice if you are looking for a small lathe in the "early iron" category.
As far as the Chinese minilathes, I have heard that they can be made to do an acceptable job after some tweaking and blueprinting. They are considered by many as "unfinished kits" as they come out of the box.
jimvannoy
Mississippi
I have an old Craftsman/Atlas 618 series lathe that does a good job. Picked it up for $100.00 at a garage sale. I use to have a Craftsman 109 series it was not nearly as good as the 618.
OldCarGuy
I have a 14" swing gear head lathe that was manufactured in China. I machined everything from brake drums & discs to external & internal threads on it. It even has the capability do metric threads. It’s a lot easier to put out close tolerance work on a good quality lathe. As it takes a craftsman and his knowledge of that particular machine can produce high quality parts.
Five years ago I purchased a 25 year old 15" Clausing-Colchester Geared Head Lathe. It weighs four times as much and a real pleasure to run. It has all but replaced my import. There’s nothing like heavy iron!
Detroit Diesel Man
MN
If you want a "Mini-Lathe" most are going to be foreign made..I have one from "Cummins Tools"..bought it off the net from their site for 299...its the 12" model and comes with accessories the others dont..was the best bang for the buck..their are alot of sites dedicated to this lathe..they range from 7x10 to 7x14...yahoo groups web sites and links can be found all over..they include plans for tooling and mods to the lathe itself..I really like mine..no problems with it at all...theirs a website that specializes in tooling and parts for these small lathes as well..posted below are 2 great links..yes they are foreign..they wont work like a souhtbend will..they have limits..but if you work around those limits and take care of the lathe it will serve you well..like I said I love mine....hope this helps.
http://www.mini-lathe.com/
http://www.varmintal.com/alath.htm
http://www.cumminstools.com/browse.cfm/4,876,0.htm
http://www.littlemachineshop.com/
http://www.mini-lathe.com/Links.htm#Home_Shops
DDM
Uncle Buck
Kansas
I think the lathe shown in jims picture should be what you start looking for. The more tooling you can get with the machine the better the deal. Machines such as the one jim showed are highly sought after, and many times bid to stupid money on pee bay. If you are impatient you can look to spend $400-500 machine and some basic tooling on up to as much as $800-1000 for a well maintained heavily tooled 6 inch lathe such as the one shown.
Jim's $100 price for that machine is rare today. Many will dismiss the Atlas 6-12 lathes as junk due to flat ways, gears made of a pot metal alloy that are easily damaged or destroyed, lathe beds that allow for too much flex and the fact that the machines are simply not hefty enough to make heavy cuts in one pass.
I do not agree. Atlas/Craftsman machines are what they are, a home hobbyist machine that simply work great for a learner or starter lathe; additionally these machines can produce accurate work given a few provisions 1) A worn out machine that has not seen enough care will not do accurate work. 2) The machines are not substantial enough to remove 50 thousandths of an inch in one pass, but neither are the import 7 x 10" jobs. These machines are easily found if you seriously start looking around.
Another good aspect of purchasing old USA stuff is you can always re sell the machine and at least get your money back out of it. I would suggest one major departure from what you are looking for if you can do it. Forget the 6-7 inch swing machines and start looking for at least a 9" machine. You will pay almost as much to play with a 6-7 incher as you will to step up to a 9-12" swing machine. Plus, you will find so many more of the 9-12 tool room sized machines out there. Another aspect to buying the larger size is a greater audience if you ever lose interest or want to upgrade!
Other good reasons to go with the larger size are, there are many other quality brands that can do heavier work than Atlas machines that can be had for the same, or not much more money. I would look for a used machine by one of the following names (not worn out) tooled as heavily at the time of purchase as you can get; on all machine tools of any type or brand tooling will far exceed the purchase price of the machine if you have to hunt things down separately. Stick to one of these used brands Sheldon, Logan, Southbend, Montgomery Ward (re badged Logan, or a Craftsman which is a rebadged Atlas) yes even an old Atlas if not too worn out would be alright if you cannot find one of the other brands first. Also try to get a machine with a Quick change gear box if you can, but I would not let it be a deal breaker for me on my first learner machine. QC gearbox prevents having to hand change out each and every gear at the headstock by hand. Which brings up another good point, if you buy an old hand change gear machine make Damned sure you get all the gears that are supposed to come with the machine.
Well, I hope that helps some! Good luck.
D
dxdexter
Thanks guy. Great links. I had previously visited a few and found good info. I certainly would like to look around further and find an older model with the tooling, but after looking for a few months have found nothing locally that is not monstrously sized and in the $3000 to $6000 range.
I just got back from looking at a 7x 12 model similar or exactly like the Cummins model mentioned. It seems quite small in person. Maybe I underestimated my future requirements.
Tomorrow I am going to look at a gear head lathe measuring 10" swing with a 18" bed. It is on sale for $999.00 reduced from $1299. It has a 5" three jaw chuck.
Heres the link : http://busybeetools.ca/cgi-bin/picture10?&NETID=0632170916071554187&NTITEM=B2227L
Any Thoughts??????????
ColdDuckTime
That stuff is all pretty darned cool. I'm tempted to get something like that myself just to learn about it...and then invent projects once I know the limitations/possibilities.
One thing that's a bummer (to me) about this as a hobby is just the sheer weight and bulk of this stuff. I went with a friend to 'help' buy a used lathe + extra stuff for $500 (a Hardinge) and felt a bit of tool lust...but damn...you're getting into hobbies where a forklift is required to move the equipment.
PAToyota
South Central Pennsylvania, USA
what do you guys think of sherline ?
My father has a Sherline lathe and mill and I've been impressed with what he has been able to do with it - also what he has shown me what others are doing with them on the Sherline discussion forum.
But for automotive type projects I'd have to say that it is a bit small - even for a small lathe. I have an old Craftsman like JimVannoy and Wilbilt mention. I'd say that the Sherline is likely more precise than mine, but mine does what I need of it and has that bit more capacity needed to do larger items.
Danglerb
SoCal
I wouldn't think of buying a cheap new lathe. Look harder or slightly less local and I am sure you will find a nice old lathe for little or nothing.
djjack
at work
Has anyone used equipment from www.knuth-usa.com
They have some benchtop stuff that seems like a good deal if the quality is there.
As far as the Sherline stuff goes I use a their lathe and mill all the time. The Sherline stuff is great when the material is soft and well behaved. I think the biggest problem with them is capacity.
mhoffm911
I have sold many lathes and "shopsmiths" over the years at auction. I recommend you check out the auction ads in your area and see what comes up. A couple of the shopsmiths that I have sold have been like new.
Detroit Diesel Man
MN
Another thought may be a 3in1 Lathe,Mill,Drill unit..depending on what you plan to do..it all boils down to what are you going to be turning...I wouldnt call the offshore benchtop lathes "cheap"..they work fine and even better with some tweaking..witch when you tweak and upgrade teaches you something new each time..the links I posted earlier are excellent links and show what a little patience and some thought you can do an amazing amount of work on a small lathe...if you have the money for something bigger great..or if you have the need for something bigger then get it..for me the small 7x12 was what I could afford..and I've modified and tweaked it and turned everything from bushings and collars for skid loaders from brass for the bushings and steel for the pins to drivers from 1018CRS and some more polished holders/parts from Stainless,Aluminum..I guess it bugs me a bit when people immediately say these benchtop lathes are "cheap" when they have no idea what they are capable of..make a list of what you plan on turning and the capacity you'll need...maybe go with a small benchtop lathe for now..learn the ins and outs of it and research projects and build your skill level..then move up to something more substantial...the problem with buying a larger used "Old Iron" lathe is you have to know how they work inside and out..alot of them arent complete..no tooling gears missing for turning threads etc..more time working on an older lathe just to be able to do a simple turning than its worth...hate to see you spend hard earned money on a big lathe only to have it collect dust in the corner in 6 months..just some more of my 2 cents on the subject..good luck with your decision.
DDM
Uncle Buck
Kansas
Or instead of buying anything, see if you can enroll in a night class at the local vo-tech. A couple hundred dollars will pay for a basic education in turning, boring, facing, and single point threading. Usually such classes also will teach you how to hand grind a drill bit and a cutting bit for the lathe. Additional things you might also learn could be a bit about manual vertical Bridgeport type milling machines, cut off saws and who knows what else! Occasionally just being in such a class will put a guy in the right place, at the right time to buy a lathe. During such a class you could also have the instructor perhaps educate you in how to access the condition of a used lathe, IE. what should you look for!
After some thought, this is probably the smartest thing to do instead of running out and buying anything, This way, when you would go to buy a machine you would already have a good basic knowledge of what your needs are, and what you want to do!
eschoendorff
I second this motion. I am taking a class (not in industrial arts though) at a community college and the quality of the instruction is A+ and very affordable.
D
dxdexter
All advice is appreciated.
Fortunately for me ,my brother has been a machinist for almost 20 years. Most of his experience in the last decade has been with CNC machining with a major aircraft engine manufacturer , but I'm sure he can show me the ropes. He has already loaned me his text books from vocational school.
Otherwise that is a great idea.
I think I will certainly learn more about what is available before jumping in, but I still am going to go look at the 10"x 18" lathe to see its quality. With the exception of this forum , I have read good things about these small lathes, Chinese or not.
When I do decide on a lathe I will take all advice seriously. I do however have a budget and can't afford an arm and a leg for full sized machines and I don't hold out much hope of finding one for next to nothing.
Uncle Buck
Kansas
I have been operating on a shoestring for longer than I would care to describe, but I would say this; you can find a decent loaded machine for $ 1000.00, they are still out there. I bought mine at auction a few years back and this is what that amount of money bought me.
(1) 1972 vintage Atlas 12" x 42" bed QC lathe, timken taper bearings in head, motor wired for revering. The following tooling came with my machine. Steady rest, Follower rest, 3 &4 jaw chucks, faceplate, several dead centers and a live center, milling attachment, full set of metric change gears, all basic tool holders, straight, left, right, parting, knurling, boring bar, several jacobs chucks mounted on morse tapers for use in the tail stock, a collet closer and a few collets, some cutter bits and a several other bits and pieces. Many of the accessories came in the original boxes and showed little or no use. The original Atlas manual also came with the machine as well as gobs of the original paperwork for all the accessories to include the motor. The lathe was mounted to a substantial wood bench with legs larger than 4" x 4" lumber.
Since I purchased the machine I have upgraded my tool post to a Phase II import clone of the ALORIS type (huge improvement) and added an Albrecht chuck mounted on a Morse taper for tail stock use. I plan on adding a scissors type knurling attachment as these small machines will not tolerate the use of a conventional knurling tool without damaging cross slide nuts at the compound. Anyway, my Atlas is tight, shows very little wear and is probably all the machine I will ever need. I think I did well for my money; and I know there are more out there for the right person.
D
dxdexter
Since I purchased the machine I have upgraded my tool post to a Phase II import clone of the ALORIS type (huge improvement) and added an Albrecht chuck mounted on a Morse taper for tail stock use. Anyway, my Atlas is tight, shows very little wear and is probably all the machine I will ever need. I think I did well for my money; and I know there are more out there for the right person.
There are some government surplus auctions coming up soon. Maybe I will luck out and pick up something along those lines.
What kind of foot print do these or similar machines occupy.
Do you have any pictures?
Uncle Buck
Kansas
On a factory stand you could expect about 24" of depth approximately 4' height at headstock and 4-5' for length. Since my motor sets to the side instead of hanging off the back of the machine and my bench was home made my bench is about 3' deep x 6' overall length, height at headstock 36-40". That is a good place to start as well as school auctions if there are still any left at schools. I would closely watch my local auctions, classifieds, and craigslist. Do not forget used equipment dealers in your area. For example here in Kansas I know a dealer in Wichita that caters to home shop type guys and as such always keeps a few old tool room lathes in stock. I would also be looking at the Practical Machinist and Chaski boards as well. Good luck, and please be patient you will be rewarded for that in the end! :beer:
I wish I did have a digital camera to take pictures of my shop to post on this board. I am very proud of my tools & equipment and wish others could see my little pile of toys. No, no pictures My garage/shop is all crammed into a 24' x 24' brick garage circa 1929 I have way to many tools in way to little a space, but perhaps that will change someday, I hope it does because I do not part company with tools very well, unless I am up-grading and even then I find it difficult to part company with a tool or machine. It is a sickness, been that way most of my life with tools!
MXtras
On the Right Coast
The forum of all forums for machinery of all sorts is www.cnczone.com Drop in and search for Busy Bee - this little lathe has some very good reviews from what I recall. Or go straight to the Mini Lathe section here - http://www.cnczone.com/forums/forumdisplay.php?f=165
I own a Harbor Freight 9X20 and as much as I hate to say it - it is pretty impressive. I bought it to perform a single operation on small pins and had planned to automate it, but I haven't yet. I would prefer a larger more capable machine, but the need doesn't justify the cost at the moment.
There is a ton of info on www.practicalmachinist.com also but this particular forum uses software that was apparently invented prior to the advent of the computer....
Scott
66RICH
Portage, IN
Here's a pic of my Atlas QC54, very similar to
Uncle Buck's. I found this locally for $250, and
will have a grand in it with tooling, and repairs.
I also added a Aloris style tool post (love it!), and
went thru everything in the rebuild. I made a chip
pan, and back splash for it.
I scoured E-bay, and want adds locally. Best advice is
ask everyone you know if they know someone with a
lathe! Sooner or later you will get a lead, that's how I
found mine. I learned a ton just rebuilding it, and it
does everything I need.
Rich (still looking for a mill!)
D
dxdexter
Thats an awesome price for that unit. I see you are looking for a mill, since I started all this research I have found quite a few articles on using the lathe as a mill. Have you ever tried this and if so how did it work?
Uncle Buck
Kansas
The Aloris style posts make a night and day difference in ridgidity and getting the most out of these smaller machines. Regardless what brand you end up getting I would highly suggest dumping the old lantern style post and going with one of this type. I got mine fron Enco for Christmas and I think the cost to my door was something around $130.00. That was for a BXA series which is a bit larger than the AXA, but with the BXA you can later fit a sissors type knurling tool to it whereas you cannot with the AXA. The old conventional knurling tools will work fine on a heavier machine such as a South Bend, but they are murder to the Atlas/Craftsman lathes as I stated earlier.
The great part of the Atlas/Craftsman machines is there are tons of parts on flea bay every day. Logan machines are still supported by Scott Logan son of the founder I think. Any of these smaller machines can easily be rebuil from end to end if you are patient enough. Nothing difficult here. The lucky guys wind up with a Southbend or Clausing ie Old Car Guy!
Something else that may be of importance to you, at least it is for some guys; is the size of the bore through the spindle in the headtock. Smaller sizes limit the diameter of material that will pass entirely through the headstock. Not counting the overall ridgidity of the machine and pot metal gears that would likely be one of the top three downfalls of the Atlas? Craftsman machines. It has not had any impact on anything I have worked with so far, but it is considered a hindrence. If you actually find an Atlas, the later and better earlier models were equipped with Timken bearings in the headstock, the more economy priced utility machines had babbit and shims in the headstock. I would avoid the babbit versions if you can.
D
dxdexter
Scott
Scott,
Thanks for those links, they are great and tons of info on the Busy Bee machine. I went and looked at it and was very impressed. I walked out without buying since I am still digesting all I have read and all the recommendations.
To be honest I'm not that patient when I decide I want something and it was all I could do to leave the store empty handed. As has been suggested, the heavier US machines are the way to go. Now I have to decide how long to wait and continue looking. I have a few jobs lined up that I could use it on right away. Oh well I guess the local machine shop will get some more business.
66RICH
Portage, IN
Dex:
No I haven't tried to use it like a mill. There are
milling attachments showing up on E-bay all the
time for the Atlas. Here's a link to a small knee
mill I would like to pick up. A little steep, but a
very good example.
http://cgi.ebay.com/Clausing-8530-V...ryZ12584QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Buck:
Mine is a PhaseII 100 series from Enco with the push
type knurler. This will do for alum, maybe I can come
up with a work around to adapt the scissors. Mine
also has the Timken bearings (circa 63). Mine was
missing the back gears, tail stock, and steady which
I picked up off E-bay.
Rich
Uncle Buck
Kansas
Dex:
very good example.
Buck:
Rich
Rich, I would like to have one of those milling machines too. Currently the only mill I have is a small Atlas Horizontal job. very limited size. I was going to buy a 100 series just like you did before the instructor in my night school shop class pointed out that a 200 would not be too big for the machine, plus the scissors type knurler could be added later; I am now glad that he pointed this out! I did knurl with my lantern style post tool once on my Atlas, I thought It was far too demanding for my machine, it felt like I was actually pushing the machine too far as opposed to the South Bend heavy 10 I used in night class, a walk in the park with that old girl!
I have never used my milling attachment on my machine, In fact I do not think it has ever been used, it was in the box with all the original paperwork when I got it. I have done alot of reading on the subject though. Most everything I have ever read indicated that that you will be very limited in what you can mill which is really a given, and that it is sort of a PITA to try and mill that way. But, if it is all you have it would beat nothing!
66RICH
Portage, IN
Buck:
I agree, the milling attachments are too limited,
and setup time is a pain. seperate machines are
the best way to go, I'm willing to wait for a deal
to come up. I try to make every Auction near here!
I just picked up an old 24" Rockwell scroll saw at
a garage sale, works great! Heavy old cast iron unit,
with a foot pedal.
Wish I would of known about the 200 series, didn't
think they would fit. I'm looking to pick up a back
rest which may may it possible to use the fixed knurler.
Get a cheap camera, and post some pics of your shop!
I'll try to get some up of mine this week. Not much,
but it's mine!
Rich
D
dxdexter
I found this Myford ML7. It appears in relatively good condition except for the compound is frozen. The elderly gentleman wants $1500 for it, but I could possibly get it for less if I made an offer.
The bed and lead screw have little or no wear and it has a quick change gear box for the threading/feed rate. Research suggests it was built after 1954 since that is when the gear boxes were available.
Does any one have any thoughts on its worth or the lathe in general? it didn't see a lot of tooling, but there is a small three jaw chuck as well as the 4 jaw.
jimvannoy
Mississippi
If there is not much tooling and it has a part frozen I would not go over $1000.00 actually probably a good bit less than that.
D
dxdexter
I was contemplating $1000. They actually still sell brand new similar models and beleive it or not they are $18000 in Canada. Link: http://www.bellmachineryltd.com/new_myford7b.htm
This one is not a Super 7 model although I'm not sure of the difference.
SteveL
St. Louis, MO
I've got a 24" bed Sherline lathe and their milling machine with a bunch of accessories. They are very good quality, but a little on the small side for automotive stuff. If I had it to do over again, I would probably be patient and find something bigger and used. It wouldn't be that much more and would be much better suited for what you want to do. My set up would probably be in the $2000 range now new. I bought all of this back in '94 and spent around $1500 for everything.
Uncle Buck
Kansas
The Myford is a quality machine, and one with quite a following in England, & I guess Canada. I think they have a reputation as a quality machine, more so than the Atlas machines that a few of us here have. Read about it right here, http://www.lathes.co.uk/myford-ml7/index.html I think testing the guy at a thousand without a great deal of tooling and a frozen compound is a very good idea. I think you will be able to find any parts you might need for it, and if he won't bite a a grand you can always add a bit more or walk on the deal! Good Call.
D
dxdexter
I know this is an old thread, but I thought I'd update my lathe search. I took the majority of advice and bought an quality older lathe and ended up purchasing the English Myford. Turns out it is from 1952. It appeared to be in pretty rough shape so I completely tore it apart, cleaned and repainted it.
As it turns out the lathe was in better shape than I thought and with the exception of a motor, required no new parts. It also included many extras which were scattered throughout the old saw mill from where it was purchased.I had to look pretty hard to find all related equipment. I purchased a low priced stand at "Busy Bee" and fabricated the mounts from HSS.
It absolutely works great. Thanks for the advice.
Here are some photos.
