Mini Split Compressor Location Question
reb162
Dayton, OH
Other than having min clearance per the manufacturers specs all around the compressor, what are the rules regarding the compressor placement out side by a wall. Specifically, the place where I want to put mine would be within 2 feet of the PVC intake and exhaust vents for my house high efficiency furnace. Any code rules I need to worry about.
rickairmedic
louisville ,Ky
Nope your fine in that location . By the way its a " condensor " the compressor is a component of the " condensor " :D . The outside unit condenses the refrigerant from a gas to a liquid thus " condensor " the inside unit evaporates the refrigerant from a liquid to a gas thus " evaporator " . This ends todays HVAC lesson :D.
Rick
Teken
The Bad Lands
Rick
Rick you and that cat always crack me up . . . :beer: :lol_hitti :lol_hitti
rlitman
Long Island
Code, no. Other possible issues, maybe.
The exhaust from a high efficiency furnace is highly corrosive. If it directly blows on the condenser coils, I'd be concerned. 2' is a lot of space though, and if the exhaust is higher than the condenser, then I wouldn't be concerned at all.
R
reb162
Dayton, OH
Thanks for ther advice, I will ensure the furnace exhaust stays away from the Condensor (not compressor ;) ).
I'm going to pull the trigger tonight on one of the following two units:
Ramsond 24000 BTU - COOL + HEAT (Heat Pump) + ELECTRIC HEAT
http://ramsond.com/proddetail.php?prod=R74GW&cat=Ductless Mini Split AC Systems
or
Ramsond 18000 BTU - COOL + HEAT (Heat Pump) + ELECTRIC HEAT
http://ramsond.com/proddetail.php?prod=R55GW&cat=Ductless Mini Split AC Systems
I keep going back and forth between the two...they are identical except for the size. Depending on the sizing calculator I use, either fits the bill for my 690 sq ft garage. I want the 24K BTU which may be on the high side due to extra losses in a garage (doors are the primary), but then I over think it and think I only need the 18K and that it will save me 400 bucks. I think I'll wind up flipping a coin.
If anyone has any last minute advice/experience on sizing for a three car 690 sq ft garage in the Ohio climate, I'd appreciate it.
Don't bother with the comments about not going name brand, etc. I've been through it and I can't afford it and name brands with back up heat strips are rare. I need the back up heat option for Ohio winters (running water in the garage).
brewchief
Code might come in to play if the manufacturers instructions give a clearance requirement, code often will defer to what the manufacturers want even if it's more then what's written in the codebook.
I've seen a lot of A/Cs that have a 6' min in there instructions.
I've also seen a lot of A/Cs installed where exhaust blows directly on them and they show no signs of damage.
If the mini is a heat pump I would want more clearance then 2', I don't see much good coming from blowing warm, moist air onto a cold coil, the unit will be going into defrost more often then normal.
