SALIV8
Well this is my first mini split problem. And I’m stumped.
There was about 4 or 5 short drips down the wall (maybe 12”-14” long) on the center/left side of this idu. It appeared to be a yellow light oily substance and I immediately thought refrigerant leak. Then I thought the drain plug might be weeping since I swapped drain locations from this side to the right side. Or maybe fan bearing or fan motor oil (if there is such a thing?)
I bought a cheap leak detector and didnt get any hits.
I shop vacced out the drain line, and removed the mini split plastic housing to see if there were any other signs where it was coming from, or more drips behind the plastic.
Nothing obvious was there? There are no signs of an active drip. How can this be? Im stumped. These drips appeared more than 2 cooling seasons after I installed this system. This is the only idu that is doing this out of 7.
This idu, like the others, was pressurized when I removed the factory flare plugs.
At this point it is now a wait and see if it re occurs because I am out of ideas.
Heres some pics. Anybody have any thoughts to help solve this mystery?
