OK, been messing with the Harbor Freight vacuum pump today to see if I am going to return it and I think that I will. It just isn't pulling down as far or as fast as I think it should and it is making some noises. When I first got it, and dead-headed the micron gauge to the port, it pulled down to single digit microns almost instantly. Now it struggles a bit to get to 150 and doesn't pull much lower.
I'm going to be doing another mini-split install in a few weeks and will probably order something like this Robinair 1550 at Amazon for about $40 more than the HF 2 stage 3cfm. It is 5cfm, two stage, and reviews are excellent.
http://amzn.to/1Ia2dvd
This FJC 5cfm "offering two-stage like performance" *is* the same price at Amazon as the HF 2 stage 3cfm....
http://amzn.to/1Ia3hiC
The FJC looks very much like the HF pumps and if you look at the placement of the different things on the Robinair pump it seems like both might be made by the same chinese mfg. Who knows. The thing is that the warranty may be better with the Robinair and maybe the FJC -- HF is only 90 days with reciept. PLUS I noted in some of the reviews for Robinair that people were able to talk to Robinair tech support! Give that a try with HF! LOL
For those of you looking for a cheaper version and in case you are not near a HF location, well there is this FJC pump at Amazon that again looks like the HF models. This one says it is 1.5cfm vs the low end one at HF which they *say* is a 2.5cfm pump.
http://amzn.to/1Ia4KWe
This is the FJC 3cfm model at amazon....
http://amzn.to/1hXlaw2
NOTE: both of those last 2 FJC models look identical to the HF pumps and they say "Single stage pump using Twin Port Technology for performance like a 2 stage performance" -- makes me wonder if they are indeed identical to the HF pumps and if the higher end HF pump is truly a real 2 stage unit as advertised.
You don't save much by going with HF or the FJC units over this Robinair unit.... looks so similar to both of the other low cfm pumps that it may be the same thing.
http://amzn.to/1EeLdsy
