rnpatrick
Hey All,
I am getting to the point I need to think about A/C for my garage. It is pretty simple, 30' deep, 60' wide, 4-bay with 13.5' high ceiling.
All 1 big room - at this point everything still open, no insulation or drywall yet.
The roof is a steep pitch and I have a ton of space to install equipment in the attic to run lines, install ducts and air handlers, etc.
The A/C calculation I had done calls for 26,000 BTU cooling load.
The attic will be unvented and insulated so putting A/C equipment up there is not an issue.
In the near future I plan on finishing some space in the attic that will also need A/C
I'd like to go with a mini-split system that will give me a single outside unit that I can use for both the garage and attic.
I can get a single mini-split wall unit that give me that cooling capacity but it is going to be terrible for air circulation in a room that big.
So one option would be to use multiple smaller wall units spread around the room but I am still not sure that circulate in a room this size.
I also see the mini-split manufacturers now also make concealed duct units - essentially like small air handlers that can be attached to ducts.
I have considered using those and running ducts to get the air distributed around the garage.
People that have done this before - would you use multiple wall mount evaporators or use concealed duct units?
Cost and labor are less factors than comfort since I will be doing the work myself.
Thanks for you advice!
RP
RP
