sammm
Hey all...getting ready to install my mini-split heat pump (Daikin), and have a couple questions.
I'll have to go thru an exterior brick wall to run the lines/electric/drain to the outside unit. What's the best way to make the 3" opening I'll need? Is it better to drill from the inside going out, or the outside coming in?
From the inside to the outside the wall is OSB|insulation|zip-wall|brick.
I'm also going to mount the outside unit to the brick wall using L-brackets to get it off the ground. What's the recommended way to mount those to the brick? Tapcon?
Thanks in advance!
Thanks in advance!
