Tracs
I have a 18K BTU Perfect Aire ductless mini-split system 17 seer, heat pump in my 24x30 garage.
Siding is dark gray hardie board. Walls are 2x6 R19, ceiling is blown in R50. 2 - 9x8 T16 doors, 3 small windows that are dual pane pvc sliders. Slab is insulated with 2" foam under, around, and up to the bottom of the wall.
I am positive the mini-split used to keep the garage at a constant temp while I was out there with all 32' of T5 lights on. Now when I am out there with the temp set to 72f the temp climbs up to 75-78f.
Outside temp is 90f.
Output temp of the air from the air handler is 50f with intake temp of 75f. I've read a 25 degree difference is not bad. The air handler's fan is set to high all the time.
Even in cooler weather the inside temp will creep up 5 degrees or so with the lights on. Are my 36' of T5 making that much heat?
2 years ago I was using the unit for heat in the winter (Manitoba Canada) and didn't pay attention to the snow and it froze into a block of ice. For real from the pan to almost the fan motor was a block of ice. I had to change the outdoor cooling fan motor and it worked after that. Could the compressor have been damaged?
