katit
I'm in a "design" phase of finishing my garage. Here is my questions. If someone can answer them - I will appreciate it.. Here in STL we have couple cold weeks but nothing too bad. Garage is 22x22 inside, 8ft ceiling with one bay raised to 10ft
1. According to online calculators in well insulated garage 18000 btu will be plenty enough, 12500 should be OK. Should I go with 18000 or stop at 12500?
2. According to mini-split instructions heat pump will work well down to 20 degrees. Inside? Outside? We have maybe 1-2 weeks of very cold. According to online data - coldest is January at low 22 degrees. I probably going to skip on electric heat option. What do you think?
3. Installation. I have masonry construction. Which means if I put outside unit on a slab - I will have to make 3 inch hole in a brick wall. Install box, etc. I have rear entry garage so the only place to put unit will be on a right side of the house if you look from the street. Aestatically wrong IMO. Wife may not like it. High traffic area. Can I place it on a roof? If I place on a roof - it won't be visible, I won't have to drill brick. Is it acceptable to mount unit on a roof? Where is box going to be? How is wire going to lay on a roof?
4. I will install inside unit on a wall in raised portion of ceiling. So, it will be like 9ft high and I will be able to get drain through the siding, not brick. Is it OK position for inside unit?
Thanks in advance!
Thanks in advance!
