fordluver4x4
I'm getting ready to insulate and drywall my shop. Before I do I'd like to run wires for a future mini-split. this means I need to know what size wires to run and where to run them.
My shop is 32x30 with 10' ceiling. I have 2x6 walls and will be doing R21 insulation, the ceiling will be blown insulation. I'm looking at 24,000 BTU units as they seem to cover roughly the correct sq ft. I'm in it mostly for the heating, but it may be used to cool once in a while as well. I'm planning to get a unit with the frost prevention mode to keep the shop just above freezing most of the time, and just heat it up more when I'm actually going to work out there. I'm in south central PA.
I'm new to mini-splits but most that I'm looking at seem to in the 240 volt 10 amp range. From what I know of electrical 12 gauge wire should be more than enough correct? The wiring stuff I've looked at for mini-splits seem to show that they use 2 conductor (plus ground) wire even for 240, two hots and no neutral, is that correct? that seems odd to me but it seems to be what I've found. So I guess what I'm asking is, will 12/2 w/ ground be sufficient for most/all mini-splits of this size? If so, can I use standard romex like I use for wiring outlets (which I have), or do I need something else since it's going to be 240 volt and have two hots?
As for location. I'm thinking either centered on the back wall ("Location 1") or over the window on the right wall ("Location 2). The location 1 wall is west facing and location 2 wall is north facing. I'm thinking location 1 is probably best because it's more centralized and further from the garage doors. Location 2 is over my work area however it's closer to the garage doors, has cabinets etc near it which could effect air flow, and it's on a north wall which means the outside unit would almost never get sun (for melting snow etc off the unit). I could also do the west wall but closer to the corner where my work area is, but then it's less centralized. Thoughts? how much does location matter?
Thanks for any insight.
