Mini-split Pressure Test/Evacuate Question
DB2
Houston, Texas
A question on mini split installation:
If I first pressure test a mini-split install with nitrogen, do I really need to use a micron gauge when evacuating the lines with a vacuum pump, or would simply running the vacuum pump for a few hours (and then verifying it holds -30" on a set of conventional gauges) be sufficient?
I have everything but a micron gauge...I'd like to do everything "right", but no sense in overkill.
jad3675
I'd do it right and use a micron gauge. You can get a Fieldpiece SVG2 for $105 from testequipmentdepot.com.
John
pop pop
Virginia
You'd be amazed at how porus your gauge set lines are and how much ref. is adsorbed in your vacuum pump oil that you'll never know....without the micron gauge.
