Mini-split question
Ztim
I have a 24’x36’x12’ tall insulated garage in central Indiana with a 2 ton, 24,000 btu min-split. it doesn’t even break a sweat. Keeps it cool and dry all summer and warm in the winter. Now, I barely open the garage doors, but when I do it recovers very quickly.
i could have gotten by easily with an 18,000 btu unit.
dcg9381
Austin, TX
Would a mini-split heat and cool a 40x64x14 insulated pole building?
It'll be 102 tomorrow. I have a 40x56x16. 2 x 24k BTU will cool that building if I manage to turn the AC on in advance. I'm old, I've been running the AC in the shop for the last 3-4 days.
Insulation is the primary factor though, I'm at about R12-R15, not outstanding... And have with 3 leaky big-*** doors.
Funny thing is, if it gets down below 25 degrees, I can't heat it because my Daikin splits were not designed for cold weather operation!
aggie113
San Antonio, TX
I have a 2 and 3 ton unit in my 30x40x18 garage (extra cooling is to rapidly add back cold air after opening garage door/brining in hot car) and today I had it set lower than I normally do on accident. It was a 100+ day today and my garage was at 76 in the late afternoon (garage was unused during the day). That is with one insulated double garage door, one insulated roll-up garage door and one man door and 2 inches of closed cell foam on the walls/ceiling.
FFRKing
Peck, Kansas
I have a 24K EG4 mini in my 30x50x12. It's a little small based on the square footage, but is actually working very well. I set it on 78 and it has been maintaining very well in the last 2 weeks of 100+ days. It's mounted in the end of the building, so I will install a couple of fans to help move the air. I haven't seen the electric bill difference yet, but it will run off solar panels and that is the plan. I've been shopping for panels recently and will have them installed before next summer. I use a propane radiant tube for heat.
FFRKing
Peck, Kansas
Also, I have 6" of insulation in the ceiling, but only the 1/4" double bubble wrap on the wall. 2-10x10 overhead doors are insulated.
TobeyA
TX
As said, insulation is the key. I have a 30x50x14, open ceiling. I should have insulated the roof better, or had an insulated ceiling installed. Spray foam on the walls and bubble wrap insulation on the 3 roll up doors. I can barely maintain low 80s in Houston in August. But if it starts feeling warm, I just step outside and remind myself what hot and humid really means.
finn
The UP, God's country
We’re about 250 miles north of the OP’s location, and I just installed a three ton (36k) BTU mini to cool the 32’x75’ x16’ high work area in my building with an additional 8k head in the 16x16x8 office / bathroom.
It seems like three tons will be sufficient, but the warmest days are past for this year. It’s been in the upper seventies for all but two or three days since the installation So I haven’t used it much. The building is pretty much thermally stable, but the mini seemed adequate for the two or three days of mid 80s weather it had to deal with.
The real benefit during those couple of teaser days was the dehumidification.
Brandon_oma#692
North West corner of Illinois
I am using mine just for cooling and dehumidification. posted a thread recently. I am about 40x100x12. I had it running on dehumidification the past few weeks and it has been great. had the shop open the past 2 days and closed it up this morning. Need to check the weather and either open back up or turn it back on. Have some stuff to do this weekend where I want to leave the doors open if I can.
lukeshotrods
my shop is a steel building 100 x 50 with 16' ceiling ctr 12 on sides. I have 2 36kBTU mini splits and will cool it in ky weather. will hold 77-78 on a 95 degree day. Iplan to add a 3rd this winter to prepare for next summer
