I just ran a recovery and only got 142g from a unit that should have 1100g charge. Unit was OFF during recovery, done to fix a leak somewhere. I stopped the recovery BEFORE it reached 0 PSI to avoid pulling air into the tank from the leak. I was expecting maybe half (5-600g) because when we stopped using it, it was still blowing just a little cold air...not much though. Did I not get all the refrigerant out? I only have 1 service port, on the low (suction) side. I did remove the shrader with a VCRT. Any help would be great. My concern is when I fix the leak and recharge with the proper weight, could I overfill it and damage it, if there is a good amount left in it. Are you supposed to run the machine during recovery in order to circulate the refrigerant to the service port in order to pull it out...then at a certain PSI stop the mini split before damaging anything?
