motterpaul
Here is my problem. Two Pioneer mini-split units - same model number, both installed on the same day by the same guy.
I did not know how complicated the install process is when he did these four years ago, we just knew he had done the job before. Well, both of them lost all coolant during the second summer season. I have had them recharged a few times - always lasts two months.
Now, I have researched enough to know this, a new (pre-measured, but not DIY) install is easier than a recharge especially if recharge involves nitrogen, finding leaks, and calculating how much coolant to add. None of the local "pros" (they had web sites and licenses) could find the leaks in either unit. My guess is that they just didn't take the time.
So, I just had the original installer come out, he has now done 30 units and has had no problems and he wanted to try a fix, so he came out and did a nitrogen test, and re-flared the lower spots, and checked the upper ones, but he didn't have a scale to measure how much coolant to add. He also did not have a leak detector but did use soap.
One possible leak was found and re-flared on one unit that is now working but the copper line is freezing. The other one seemed incapable of taking a full charge based on his pressure gauge (again no scale was used), so the air output feels dry, but not cold, but the copper line is cold to the touch.
Anyway, I am wondering if I should just buy two new units and get them fully installed. Or if I should just buy new outdoor units where I know they will come with the right amount of coolant (and of course I am assuming the leaks have been fixed) and then I would connect what I can and hire a pro to come and double-check the install and load the coolant.
I already know this is a flawed and loaded question - but I am retired and already spent too much of my soc-sec (kidding, but only a little).
I am asking the pros to see if they think it is highly possible he did fix the leaks but just didn't know how much coolant to add to the refill?
