danb35
I'm building a 30' x 40' x 14' steel building as a workshop, and I'm planning on a mini-split system to cool (and occasionally heat, but mostly cool) the shop. But I'm having trouble getting consistent information about the BTU requirements--I'm seeing numbers ranging from 16k BTU to 95k. The latter is an outlier, but even discarding that I'm seeing quite a wide range. Hoping for a sanity check on what I'd need--I definitely don't want to undersize the unit, but I don't want to significantly oversize it either (it costs more, and what I'm reading indicates that it reduces comfort levels anyway).
I'm in coastal GA near Savannah. The building is 30' x 40', with the 40' dimension and the roof ridge running N-S. It's a metal building with a 3" fiberglass insulation blanket covering walls and roof/ceiling. Eave height is 14', with a 4:12 roof pitch. It will be on a concrete slab.
There are eight 32" x 52" windows, three each in the east and west walls, and two in the south wall. Two 10' x 10' roll-up doors, and one walk door, in the north wall.
The interior is open, except for an 8' high, 8' wide mezzanine across the south end of the building. Below that, a 24' section is enclosed--both of the windows in the south wall are in that section.
I'll be the only occupant of the building most of the time, and it will be for hobby use--I won't be there full time or anything close to it.
Hopefully I've given enough information about the building--how should I size the unit?
