I have a set of mini-split wall brackets that I ordered with the mini-split unit.
The place selling them says they are just fine for the unit.
The install manual says I need more than 12" from the back of the unit to the wall.
The bracket doesn't give me that option. The unit itself is 13" deep and the bracket is only 18" deep. So that only leaves me 5" between the wall and the condenser unit.
So would you believe them and install it, or would you fabricate something else to push the condenser farther off the wall?
The wall is 74 inches wide, and I plan on running the line-set out from under the eave and right over to the unit. I will probably go with PVC pipe as I can't bring myself to pay those crazy prices for line set covers again.
Since the main house compressor is right there in that nook, would a new compressor interfere with the old one if I mounted it up high above it?
This is the outdoor unit:
This is the indoor Unit:
