Chaz
What exactly are they, and what are the advantages? I'm building a 500 sq ft apartment and it seems this may be the way to go.
I'm having trouble locating basic info.
No expensive and inefficient ductwork. Easy install. The noisy part is outside. Efficient and economical.
Pro installers want a lot more to install them than the work reflects imo. I personally think they are looking at a lucrative trade becoming less so with the easy installs and less work required , so they are bad-mouthing them. My opinion only, formed after speaking to some pros and ending up installing my own mini-split myself. Works great, by the way.
They are reversible heat pumps. In hot weather they take heat from inside and send it outside. In cold weather they take heat from outside and bring it inside. When in heat mode they lose efficiency when the outside air temps are below ~ 30F. Some have an added heat strip for those occasions (making it basically an electric heater).
I have two - one in the garage, one in the room above the garage. Here in North Carolina they work great - very quiet and energy efficient. Not sure about Montana - you likely have a lot more very cold days than we do.
I installed then myself then paid an HVAC tech to evacuate the lines before opening the refrigerant valves (they come pre-filled). As mentioned above, some HVAC companies charge a lot of money for a relatively easy install. In my case, I don't think any of them had any experience with the units so they were hedging their bets on the installation. Seems like a good place to negotiate the cost.
