Mini Torx screwdriver set recommendation?
Kuma601
Cali
I'm looking for a mini set that covers T5-T10 range. This is a low use tool so a mid priced set is acceptable. Want to keep this below $30 with $20 range being optimal. L keys are also an option if the shank size is small so that they can be cut to use in pin vise handles.
I see EKLIND 92200 PSD for $20
Milwaukee 48-22-2610 for $21
Other suggestions/recommendations?
whateg01
doo dah, kansas, usa
I'm very happy so far with my Klein set. I especially like the case. I have a couple other sets with the fancy bit storage that rotates up. One still works but the other broke so it's a pain to close it now. This case lives in my tool bag I travel with and has held up to the rigors of that. It's not the individual drivers like the others, which can be nice at times, but it works for Uses.
Klein Tools 32717 Precision Screwdriver Set with Case, All-in-One Multi-Function Repair Tool Kit Includes 39 Bits for Apple Products https://www.amazon.com/dp/B08DRVM38X/?tag=atomicindus08-20
Spud McGee
Walmart use to carry a killer set in a little clear and red plastic case for $5. Not sure if they still do. I bought about 10 of them a few years back and stashed them all over the house. t4, t5, t6, t7, t8, t9, t10x2, t15x2, t20x2. Plus all the other hex, slotted, and phillips ones.
The husky brand set isnt bad. But not as great as the walmart one.
EDIT -
this looks like the current version. https://www.walmart.com/ip/Hyper-To...-type-Screwdriver-Bits-Set-TS99913A/664156679
Mooky
PA
Take a look at the equipment you’re working on. If the screws are recessed in the housings (deep in there), the diameter of the bit holder and length of the bits on the interchangeable tip sets might be an issue. The Klein has a small diameter bit holder, but still might not fit into deep, recessed holes.
A set of drivers like: https://www.wihatools.com/products/precision-torxr-screwdriver-8-piece-set-t1-t8
always fit, but not as convenient as the multi bit sets.
  • Like
Reactions: LSU
K
Kuma601
Cali
Those bit sets look nice, was not aware of that Wiha mini bit set. Was looking for individual drivers in this instance but the bit set is useful so I'll pick one of those up as well.
The Husky precision set is $15, good price and it has other bits that are useful. Would have to check Walmart if that set is still available.
Before Wiha had hard handle sets but looks like those are discontinued for the soft handle variants. The hard handles were easy to clean when dirty.
Spud McGee
I just went to my local store to pick up another one of these for a toolbox I just put together. The one I linked above was $6 in the store. Right beside it was another one for like $12 that had a lot more bits in it. Torx starts at T2 in this one. And it has triangles, tamper proof torx, and Ys and all sorts of ones that aren't in the other one. I think the cheaper one has a couple more duplicates in case you need them.
K
Kuma601
Cali
Cool! Will hit up Walmart tomorrow. My set is the wing handle yet it made me realize that a bit set or individual drivers would be nice to have.
What motivated this is that I offered to help a local knife shop get a knife working for a customer of theirs. The owner had modded it with a titanium screw set that has terrible specs. This is the condition of the screws:
Grokew
Home
Wiha also has this one on sale
Wiha 75958 36 Piece GoBox Precision Micro Bit Set https://www.amazon.com/dp/B0BLWJW8WH/?tag=atomicindus08-20
Draftpick1
wera has a Torx plus like the Hex plus it has a little different profle to help with stripping bolts, also mac has some RBRT torx. looking at the conditon of the screws you will need some kind or extracting bit or one with a different profile to engage to screw at different points
KnurledNut
n/a
The discontinued Channellock TP-5A set would get you T5-T9.
It looks like Bowers Tool has them on ebay for $18.94 shipped:
https://www.ebay.com/itm/Channellock-5pc-Precision-Torx-Star-Screwdriver-Set-TP-5A-T5-T6-T7-T8-T9-USA/132368128627?epid=2254324646&hash=item1ed1c15a73:g:8GcAAOSw0ndZ5-A-&amdata=enc:AQAIAAAAwOffYVB8v2kej5mMkkNC4ZBFv3M/NeXdKgHe1OskYspboI1ZkWh0OIYuB84pK7ExVLWYB1Q5+tbAhKnfWIj+RUWHHj7QQY/gQPlsM4zU0guK4JbIbZC/Nev1btt0XkMClPWhBBhyYgNMKhw/D2hjPIoMQeN7GkAxYQQ+SX0Kvo8EaFTWR9u68729n+LWKDagy5m9mQW3BuhLOMa5DcuCkoPXt91ximnUTb38WchTXh24qCKhEwUkYiHVBftv2+ZR7A==|tkp:Bk9SR9zs2P_6YQ&pageci=bf439c53-4b69-4ac9-b3c9-e6216e567063&redirect=mobile
Tallpilot
Orlando
I have that set in the PicoSoft handle version. I like them very much. Wiha has been my go to for precision drivers.
K
Kuma601
Cali
Others must have seen your post as the 77 piece set was raided. The 17 and 44 piece set is not anywhere in the area here. Stopped by HD to look at the Klein set and even though online it showed 8 sets available, none were there. Headed to the tool section and picked up the Husky 25 piece precision set. I don't think I'm going to like that small handle so I've not opened it. That one is from Taiwan.
Now in unfulfilled and irritated mode. It isn't supposed to be this difficult to enjoy some local shopping. :(
ItsNemo
Canada
Be aware that some of the cheaper sets use a softer metal for the bits, so if you get a fastener that's a little stuck, you'll round over our twist the bit.
This can't be emphasized enough, don't go cheap on these small sizes...the fit/tolerances on the cheap bits are terrible and they will just mangle the fasteners. I'd recommend Wera or Wiha.
darkzero
SoCal
Depends on what you work on? Looks like knives but only knives? Well for me anyway I use different sets for different things.
These 2 sets I use for general purpose & for my knives. I have a lot of knives & work on a few of my friends' knives also. I've twisted these 4mm shank bits working on knives, mainly the T8, good thing is you can just buy replacement bits. The Wiha is a good set but expensive, even more expensive these days. The bit ratchet helps for the tight stubborn screws. The other one is just a cheap set that I got from Fry's way back when.
These classic Wiha drivers I use for working on electronics. The 4mm bits above often won't fit in recessed holes.
These torx flag drivers I use exclusively for my machining cutting tools, for the carbide insert screws. Much easier to use & torque down than a screwdriver style handle.
I've got others but you get the idea. Not saying you need different styles of drivers but they do work better for different tasks. Just something to think about. I accumulated all my stuff over the years, had no idea how different style drivers would be much more useful for the things I use em on.
Bubba Fett
Eastern NC
When it comes to precision screwdrivers, Wiha is my favorite. Wera is good, but often pricier, and I don't like the handles as much. iFixit also has a good line of precision drivers, as does Klein. Bestway used to have some good offerings, but they are harder to find. Mayhew will probably re-introduce a lot of those at higher prices, if they haven't already.
Most of the cheap sets found in stores are apparently made out of butter.
ecotec
Does Menards still have Masterforce USA?
They are nothing special, but mine have held up.
K
Kuma601
Cali
This buggered up knife is not my normal yet it did show me there is a gap in tool availability here.
The wing Torx I have are Wiha and an old T5 Wiha has been excellent. I wish that I bought the others up to T40 in this handle. I've been using the T5 for the past 20 years and it has not been a failure point for snugging up small screws. Two of these drivers were cut off for use in pin vises. When I think of the cost of the Wiha driver and the French made pin vise, it adds up. I use the T5 frequently so the expense was worth it.
That said I ordered the Wiha 75958 36 Piece GoBox for $29. Eventually the 7 piece 26792 set for $41 will accompany it.
boyleged
Cincinnati, Ohio
I'm into knives and the best torx I've found have been the all red handled Wiha shown above. I bought them after a recommendation from someone working in a tool crib in a large machine shop. The Wiha's held up the best when working with insert screws and I have yet to waller out a fastener with them
