milky2k
I've been interested in getting a mini universal bender for some small projects I'd like to do at home. There aren't many youtube reviews on these but I did find a couple for the Almhs version of the bender. The review calls out issues with the bender like sloppy tolerances but also some remedies to make it perform better so I guess that's good. Amazon has several clones under different names as usual that vary in price from $50- $90. But then I saw that Micro-Mark sells the same kind of bender as well but once shipping and tax are included its almost $150. I have no problem spending that much if it is indeed better than all the Amazon versions but if it isn't, then there isn't any sense in over spending. I was hoping some of you may have some experience with these benders and can chime in on which one to get or avoid. Thanks
https://www.amazon.com/dp/B06XRTV1H6/?tag=atomicindus08-20
www.micromark.com
Universal Bender
DetailsBend Metal Wire and Strip into Complex Shapes with Ease Now with Expanded Tooling Set!Bend metal wire and strips in complex shapes with easeCreate S-curves, squares, coils, and moreClamps to bench-mounted vise or mount with boltsMade with rust-protected steel12-inch lever with rubberized...
