1 - Clean the area to be sealed. Use high quality concrete or masonry cleaning agent like Wolverine Coatings OrganiClean 935, an industrial strength general purpose cleaner and degreaser. OrganiClean 935 is highly concentrated and can be diluted with water up to 100 to 1. It’s a great cleaner to have on hand for many general shop, garage, and household cleaning needs.
After washing with the cleaning agent thoroughly rinse the area with a high pressure washer.
2 - For the most durable coating we recommend the surface be etched with Wolverine Coatings OrganiPrep 921, a non-toxic, low odor concrete etcher. Alternately muriatic acid can also be used for etching. Muriatic acid is toxic and extremely caustic, carefully read and follow all product directions. After the etcher has been allowed to work per package instructions, thoroughly neutralize and rinse the surface. Check local regulations about the use and disposal of chemicals and coatings.
Allow the concrete to dry and check for liquid penetration by pouring a small amount of water on the surface to be coated, if the water is evenly absorbed then you’re set to apply the sealer. If the water beads up you should take additional steps to profile the surface before applying AcryliSeal 3501.
When the surface is clean and dry, and you’ve confirmed that liquids can penetrate the surface, you’re all set to apply the AcryliSeal 3501!
After applying AcryliSeal 3501 the finished surface will have a “wet look” which will also enhance the color and shades of the underlying material.
To enhance that wet look even more, apply separate coats of AcryliSeal 3501. When applying the first coat, and for the first coat only, mix in clean warm water with the AcryliSeal 3501 - add two quarts of warm water for every gallon of AcryliSeal 3501 and mix thoroughly before applying.
For the second coat use AcryliSeal 3501 at its normal undiluted strength.
3 - Open the pail and thoroughly stir contents for 60 seconds. Apply to dry surface at about one gallon for every 300 square feet.
You can use a high quality 3/8” nap, no lint, no shed, paint roller cover, brush, airless sprayer, or a garden sprayer. The important thing is to apply the AcryliSeal 3501 evenly and be sure it penetrates the surface!
Allow the AcryliSeal 3501 to dry before applying any additional coats. Drying will take about 3 hours depending on weather conditions. AcryliSeal 3501 is typically applied in at least 2 coats.
AcryliSeal 3501 can be slippery; to reduce the chance of falls and slips you can add Wolverine Coatings SuperGrip 850 grip additive to the final coat of AcryliSeal 3501. Use ½ pound of SuperGrip 850 for every 250 square feet.
Be careful not to spill AcryliSeal 3501 on any surface or item you don’t want to coat!
Clean up immediately with clean, soapy, water.
