Minimal grinding?
Hank11
Tennessee
I think I could give my floor a quick sanding/grinding at about 200 grit to get an even “color”. “Color“ in this instance means a fairly uniform surface all over in prep for finishing with a clear sealer. Is there any reason not to do this? Can it be done? What machine?
WisJim
Menomonie, WI
Sanding or grinding, to me, are quite different. I just used 80 grit sandpaper on an old varnished oak floor as prep for new finish, and can't imagine it doing much to concrete.
KYCountryboy
200 grit sanding on a coating may be just fine for applying a refresher coat -provided it's well bonded. 200 grit on bare concrete will not do the job, you need much much more aggresive abrasion.
