blint
I am looking to make a minimalist truss press for a shed I'm building. One-time use for this shed and never again. I don't know if the design I'm contemplating will be adequate, since what I've seen people do here and on videos is a left heftier than what I have in mind. I would gladly rent a big hydraulic C-clamp with a porta-press, which I see are available to rent in Australia and New Zealand, but I haven't found anything in the Philadelphia metro area where I live.
I have three 1/4 inch steel plates (12x18) with 5/8 holes at the corners. I thought I'd get a (manually operated) 20-ton bottle jack, and some 5/8 threaded rods, and make a "sandwich" with one of the 1/4 inch steel plates as the base resting on a 2x10, with nuts at the corners flanking the board, the roof truss resting on the steel plate, the gang-nail connector plate placed on the roof truss joint, the bottle jack base plate sitting atop the gang-nail connector plate, and then the doubled-up two 1/4 steel plates at the top, everything bolted together tightly using four 5/8 threaded rods and washers at the corners.
If the top plates deflect, I could find a smaller 6x6 or 8x8 steel plate to put on the bottle jack's ram to help address the deflection issue. But is there a particular kind of 5/8 threaded rod I should use, one with high strength? I wouldn't want them to snap.
Is there a glaring problem that I haven't even thought about?
P.S. The advantage of this hack over another hack, using steel plates with an impact driver, is low noise. I've tried that impact driver and plates approach, and it works OK, but it is very noisy. I'm sure the entire neighborhood would be upset with the incessant jackhammer sound of the impact driver.
