Minimax T3 shaper weight
Beebazaar
I'm picking up a T3 wood shaper soon. Unfortunately it's in the basement of an old man's house. I need to carry it out. He says the top is removable. Does anyone have one that can confirm the top comes off? Know the Weight? Any idea how much the top weighs?
Thanks!
jar944
Northern VA
Thanks!
I'd guess 6-700lbs overall could be a bit more or less. The top should have the quill and motor mounted to it so it's most of the weight.
Beebazaar
for future reference if anyone asks, since I couldn't find any info on this anywhere:
The sliding table probably weighs 50 - 75 lbs
The rails it rides on probably weigh 40 lbs
The rails are held on by 4 allen head bolts - metric
The top of the rails have bump stops that can be loosened and turned. you must turn 1 of them to remove the table, it just slides right off and on. The wheels have a bearing cover of sorts, i believe to clean the track off as you slide. be careful, I could see them breaking easy.
The fence is 15 lbs or so
The cast iron top weighs, id guess 150 lbs. I can move it on my own, but its easy with 2 people. I dont think id attempt to put on or remove from the cabinet though, especially with the studs attached to it and the spindle housing.
It is held on by 4 nuts. The top has 4 studs and rubber feet. 1 is outside the cabinet and the other 3 inside, easily accessible.
The motor and spindle are also bolted to the top with 4 bolts. again easily accessible. - all 8 are 13 mm
The issue is once the motor and spindle are detached, they have no support and the wheel to raise/lower looks to be a chore to remove.
I put a 4 x 6 block across the bottom of the cabinet and lowered the motor until it rested on the block. then removed the bolts. after this the top lifts right off. I took a lashing strap and went around the motor and the door jam to hold it from moving around during transport. don't crank the strap. I had no issues on a 320 mile drive like this.
The cabinet I strapped to a dolly, it is the heaviest part. I guess 250 lbs or so. on the dolly and 2 people, up and down stairs were not bad at all.
all in all, im guessing ~525 lbs. easily took apart and a moved. Hope this helps someone in the future.
The shaper is really nice and I cant wait to use it!
