Minimum ceiling height for a loft?
BellyUpFish
Alabama
Looks like my plans may be changing just a bit for my 40x50. Looks like it may become a 40x40. It's not definite yet, but we are thinking about a poured concrete safe room addition to the house and that will eat into my 40x50 budget. I could always "just spend the extra money" and build the 40x50, and I MIGHT, but those of you who have a loft..
What would you say is the minimum celing height for a usable loft? 16' or so?
USAFpj
Upstate, SC
Hey Bellyup, depends on your height! I went with 14ft sidewalls. At 5'10", that will give me 7ft working room downstairs, roughly 12in of mezzanine flooring, and 6ft of loft height before I smack my head on the bottom of the truss. 16ft would be better, but you have to draw the budget line somewhere!
NUTTSGT
Northern Central Ohio
What do you plan on using the mezzanine for ? Work area, hang out area or just storage. It one requires a different number in my opinion.
toomany
Auburn, Mi
I went 14' with mine. I have just enough room standing on the loft. I'm around 5'10". I don't know off the top of my head how much room is under it...but it's plenty.
Some in progress pics of when it was going up.
D. Patina
Texas
Toomany,
I was admiring your loft. I have a 36w X 30d X 12h pole barn going going up. I basically see how you did it. Looks like it's 30 feet long and about 7.5 high. Are the 2x6 posts you built anchored to the floor in some way.
zkdiesel
chicagoland cornfields
14' works if you compromise upper height a tad where you might have to crouch. If it's a small loft and only storage it's a good compromise for affordability to build and to heat and cool! Way taller buildings require much more energy to heat and cool
lostmind
Wellington,Ohio
If you put it in the gable end , 10 foot wall is enough if you just use it for storage
and you put it between the trusses. 7.5 foot below , stand up in the middle.
Kind of depends on your roof pitch.
I have a "mini-loft" ! Okay, it is just a big, heavy duty shelf about 4.5' off the ground and it comes out about 4' from the wall. Great space up there.
I think the real question is, do you need clear head room under and above the floor and joists. 7' above and below should be good.
Boy, is it nice to see someone who actually KNOWS how to build proper structure ! The double beam is resting on top of doubled 2by uprights. The third locks it all together.
Dragfluid
Pillager, MN
My walls are 14'. When I framed up the office area, I went for a 7' ceiling. Using 2x6's for joists up above, it gives me almost 6 1/2' of head room up above.
Was this loft just going in a small area, or the whole building?
