drummerdimitri
After having removed the tiles in my workshop, I noticed that about 1/3 of the existing concrete slab is 5 cm higher than the rest of the area.
I would like to pour new concrete over the existing slab in order to close the 5 cm gap and have a flat and level floor.
For the 2/3 of the surface area being at a lower level than the rest of the workshop, I was told to insert expanded polystyrene blocks to fill in the gap and then pour a new slab on top of that.
Now my question is what is the minimum slab thickness I can get away with in this case? Cost is not an issue but weight is since the building is old and was ill maintained throughout its 60 year old life and so I would like to reduce the weight as much as possible.
The workshop will be used for light to medium duty metal fabrication and the main activities will be grinding, plasma cutting, welding, machining etc.
