cccoltsicehockey
I had my first meeting with the AC installer my builder is using for my project after he had sometimes to review the plans. In the same time I have been reading a good bit through this section. Based on what I have read I feel like the suggestion I was giving might be extremely oversized for the application and thus might not function well.
For some background the strucutre has roughly 2285sqft to be heated and cooled. The two garage bays have walls that are 13ft and vaulted ceilings that are 22ft high at the collar ties. The one roof is a 12/12 the other is 14/12 so that the ridges met at the same point. The loft area will be heated/cooled to 72 year round. The rest of the space will likely be left at 56-78 range or whatever naturally occures in the middle based on season unless I am actively working in there. The building will be R19 walls, R38 roof, and R16 garage doors. We will be insulating all interior walls as well do to possibly having things cooled to different temps in different areas as well as for trying to keep the noise contained in the corner shop area. Working Garage Bay 2 will have 4 windows and the garage door. Storage Garage Bay 1 will have no windows, a person door and a garage door. I will also be doing an 84in ceiling fan in both garage bays to aid in air movement.
When I spoke with the contractor he said his calculations came out to needing 1.5ton units for each garage bay but he was concerned that might only be able to cool me down to 73-74 in the summer and that he suggested bumping up to a 2ton unit. He then suggested a second 2 head 2 ton unit that would cool the corner shop and the loft upstairs.
As mentioned from reading suggestions in this section 6tons for this amount of sqft seems like extreme overkill to the point it may not function properly? Am I reading things right or are these really closer to being correct.
