Minisplit - Condensate Pump
justsam
Penngrove, California
My daughter recently purchased a D.R. Horton production home near Portland Oregon. It is a 4 bedroom and has an upstairs and a downstairs Mitsubishi minisplit.
The upstairs unit is leaking condensate down the walls, she has learned this is a common problem via discussions with neighbors. I took a quick look at it and it looks like there is a condensate pump in the attic, at least that is what other neighbors have advised, and they fail on a regular basis.
On these units, how is the demand to run the pump sensed? At the unit or at the pump? Looks like perhaps the unit has either a control circuit for the pump, or perhaps is low voltage feed to operate pump?
Builder has been little help, and has already spent lots of time and money trying to remedy distribution issues in the homes, with little satisfaction from owners, so I really do not know long term resolutions. Next time I visit I will take a better look, but for now trying to determine what I am up against. I am familiar with float sensing type pumps, but in this case, assuming it is in the attic, it is uphill flow.
Jackfre
N CA
Check the wall for plumb. Many leak due to a wall that leans into the room. Check out Aspen condensate pumps. They make a compact unit that mounts just below the evap is much less intrusive than water running into the room.
mrpizza
IL
Aspen has an orange pump for ductless that can be remote mounted
Search rectorseal 83919
SALIV8
chicago and s/w michigan
If the water is leaking down the walls at the unit, take a look in the unit and see what's going on. Is the condensate pump in the unit or somewhere else?
J
justsam
The hose to the condensate pump is NOT a gravity feed to the pump, which according to others is buried in the attic under many layers of blown in insulation. The issue seems to be a recurring problem with other town home owners in the development.
Because this is NOT gravity feed I was asking how or where is the sensor to activate the pump which must draw the condensate UP first and then down to an outside location.
SALIV8
Those types typically have a mini condensate pump hidden in the unit somewhere (like right below the pan or similar but still inside the unit itself so you can't see it. Have you opened up the unit a bit to see?
