skwurl
Hello . I;m buying a Miracle Truss building that was never put up. It has detailed directions for erecting it and nothing on the slab and footers. Any info would be helpful
What the heck is a "convening authority?" I've only lived in cities and they all have "building departments." (Or similar.)
Think he meant "governing authority" but spell checkers sometimes fix slight misspellings with things you don't want to say.
Charles
Yea this one's been sitting for a good while . If it's rusted up when we go to load it I'm walking awayI helped put a single miracle truss building up twice. Helped tear it down once to move it. Pretty straight forward design that is pretty easy to assemble with just two guys and some scaffolding. If you get the assembly instructions you should be set. Check the metal for the roof and walls. The one I did sat for a while with the metal stacked and it had a ton of rust pin holes in it.
A slab is not needed until after the building is put up. We boxed out a form for the footers and went several feet into the ground. the measurement for the footer bolt spacing when measured from opposing walls is critical. We did the first building a little too close and could not het the truss plates to bolt to the wall plates properly. From what I remember also really look at the spacing on the footer bolts four corners. They are slightly different the spacing on the walls. The first time we put it up the bolts wound up way off on the corners for this reason. The second time we got it right.
Chris
I built a Kentucky Steel building which is very similar to Miracle Truss but was about half the price. They specified 20" (round or square) concrete piers under each post. IIRC the piers were 3'-4' deep. I could have used cardboard sonotube but I made my own forms for square piers. I poured my slab around the piers a few years after I built it.
http://kybuildings.net/
One in the sameWhat the heck is a "convening authority?" I've only lived in cities and they all have "building departments." (Or similar.)
See above^^^
Charles
OK because I was wondering if the military was going to be involved.![]()
Going to pick it up today. I really hope it's not rusted all to ****.
