Curious as where you work^^^
I work at a remote mine site in northern Canada
Gives me a reason to keep buying more tools![]()
My thoughts exactly!
Vices are intended to take a beating. Most of them have flat and curved sections on them specifically for that reason. That's not abuse at all.
Bench vises are made of cast iron and will crack if hit hard enough. Tapping on sheet metal is OK.
The only vises you are supposed to really pound on are post vises for blacksmithing.
Usually using my tape measure or drill to adjust something. Just a tap or two to get something positioned properly.And yeah I've also used the screwdriver pry bar and pliers hammer.
I think this one speaks for itself... angle grinder becomes bench grinder, with a little help from the Record Junior
Please be careful, if you fall off your high horse you might severely injure yourself.![]()
oil filter pliers to compress brake caliper pistons when convenient (very often, actually its faster than using the proper tool)...
When the harvester is down and the crop needs harvesting there is no such thing as tool abuse... It's all a matter of perspective.
lg
no neat sig line
