Misc. Tools
Crossfire05
Utah
Take a look at these two tools and let me know if you would deep six them
1) Flexible Screw driver
2) Stanley Hex-a-Matic
ssdave
Eastern Oregon
Put them in the classifieds once you get to 100 posts. There was someone looking for one of those hex a matics a few months back, was lamenting that a co-work had taken his. The flexible screwdrivers are near worthless, but might fill a particular need for someone. I have a snap-on one, so they must have even thought it was a good idea at one time. The problem is they're not strong enough, and kink and pull out of the slot without putting much torque on the screw.
C
Crossfire05
Utah
Here is one more, small wire cutter with Newport imprint. It has alligator skin like imprint on handles. How old is this?
LXCam
Personally I'd keep the flex screwdriver. It might only be a couple times a year but my flex extensions save my ***.
gaswizard
I had the same screw driver and got not even one use out of it before it broke. Toss it into the metal scrap pile
bsg1
so cal
the 'Vacuum Grip/Newport' marked wire cutters are high quality and have some collectible value. Forged Steel Products was the parent company of Vacuum Grip pliers.
Forged Steel Products contracted with and suppled Snap-on with what became the Snap-on Vacuum Grip line of pliers/other. Forged Steel Products also provided other hand tools to Snap-on that were included in the Blue-Point brand of Snap-on tools. Snap-on acquired Forged Steel Products in 1945.
C
Crossfire05
Utah
So it is pre 1945. Interesting.
ssdave
Eastern Oregon
I'd use those cutters, they're very good. I recently wore out a pair, took me about 7 years of cutting hardened wire. I got them used, and they replaced new Kleins that were wearing out in a month or less of use. When they got dull and weren't cutting as well, although they still worked, I replaced them with Snap-on, which so far have held up for a couple of years, although I haven't used them as heavily as I was using the vacuum grips.
kjbenner
NE Ohio
Even if those cutters are a little worn out you might want to hang onto them. I keep a couple pair of dikes that are dull around, I find them good for pulling cotter pins and those little plastic automotive body fasteners without cutting them.
C
Crossfire05
Utah
Great Info! Thank you for all the feedback. One more for you. Pair of Stillson? pipe wrenches and a wrench by BA CALO?
C
Crossfire05
Utah
Here are two wrenches that I would like identified if possible. One is 11/16 and 5/8 with the number 93 and chrome molybdenum on it. The other just says carbon steel but has a odd cut to it. Again keep, sell or ditch!
