Miter box or hand miter saw
rodster_67
Near Allentown PA
I have some small pieces of molding I need to cut and prefer not to have my hands that close to a spinning blade so I was searching for a nice miter box or hand miter saw. Other than the cheap plastic things, seems the big box stores don't carry much and what they do carry don't get very good reviews.
Any suggestions where to look? Not looking for a high end professional model but it would be nice to have a solid unit that makes decent cuts.
Thanks
R
rodster_67
Near Allentown PA
Checking this one out on CL. Looks to be a decent unit. I have to check the quality of the saw, anything else to check?
TomB19
Regina, SK, Canada
If you have a table saw with a sled, that would be better still. You'll get less blow-out and more precise cuts with a table saw.
R
rodster_67
Near Allentown PA
Yea, I figured worse case is the saw will need sharpened. Looks like an older solid unit.
No table saw, :sad: I will have to buy more tools to build my garage addition to house the tools I need to do my projects and will need more storage for the new tools to build the addition which will be too small when I get done buying all the tools. :D
Does it ever end?? :dunno:
PBCampbell
WV
Looks like a Craftsman from the 70's maybe. I have one somewhere, but haven't used it for at least a couple decades. Worked well enough from what I recall. Having a sharp properly set saw will be key.
R
rodster_67
Near Allentown PA
I asked the seller if it had a name on it, he is checking (if he remembers) I wouldn't mind adding an old Craftsman Miter Saw to my collection!
Maybe it wasn't used hard and the saw is decent. We'll see.
turbowoodworker
Apex NC
Rodster, I have that exact saw. Bought from Sears about 1982. I still use it for small stuff. Best piece on it is the saw, very high quality. Beware there are rubber O rings that are long gone, disintegrated. But it seems to function as if it never needed the "bushing" function of the O rings.
TomB19
Regina, SK, Canada
Futility is a big part of the enjoyment of this hobby.
Stuart in MN
Minneapolis
The miter saw in the picture above should work just fine. My old roommate had one, it was accurate and for cutting trim was nearly as fast as using a table saw.
fivespdcat
For cutting small trim, I miter first then cut for length. I sometimes scrap a few but it's better than losing fingers or wasting time going out somewhere and buying something that may work.
R
rodster_67
Near Allentown PA
Thanks for the info guys and turbowoodworker thanks for the positive ID. Assuming the saw hasn't been used to trim tree branches and the rest of it is decent I think it will be worth $15 to take a chance on it. ;)
rharman
SoCal
I have a similar one.
Clean, polish, wax, lubricate, sharpen.
Fasten securely to a stable bench.
Go slowly and securely fasten the work and the cut will be smooth.
Bill
Absolutely worth $15. I have one. It's a Craftsman model. As Bill said, you need to keep the vertical guides and rollers clean and lubricated. It works quite well but I have tended to go to my 10" power miter saw for quite some time. The manual one is garage sale material soon.
