ckucia
Recently bought a Dewalt sliding miter saw. Very nice machine although expensive.
So I have my old Craftsman 10" 5000rpm basic miter saw. Have had it for probably 20+ years.
Wanted to find something to do with it since it's not worth much on Facebook Marketplace. Could really use something for cutting metal as even a portable bandsaw is out of budget right now and a hacksaw gets old fast. Angle grinder is always an option, but I realized of all my tools, that one has injured me the most, although thankfully never seriously.
So like many, I started researching whether I could use some sort of cutoff blade on the old miter saw.
I know this has been kinda beat to death, but... One of the arguments I see against this is that "wood saws run too fast" or "metal chop saws run slower". But looking at chop saws, they're running around 3800-4000 RPM with 14" blades. I see 10" metal cutoff blades with a max RPM rating of 6000+ rpm. When you do the math, the circumference of a 14" blade is about 44" and a 10" is about 32". 44" @ 3800rpm is 167,200 inches per minute at the edge of the blade. 32" @ 5000rpm is 160,000 inches per minute at the edge of the blade. That seems like a pretty negligible difference to me and the wood miter saw with the metal cutoff wheel is actually the one running slower.
There are other valid arguments against doing this - the motor not being sealed and exposed to metal dust, the blade guard being plastic (although the upper half on mine is metal), inability to solidly clamp unless modified. But I don't see the speed as being a problem.
On the plus side, using a wood miter saw with a metal cutoff blade seems safer (by virtue of being more controlled and less exposed) than using a typical angle grinder by hand with a large cutoff wheel. A 9" angle grinder runs at 6500 rpm (that edge is moving at 183,690 inches per minute) and half the edge of the blade is exposed along with one entire face and half the other, right next to your hands. If I were to put a 10" metal cutting blade in my miter saw, (removing the plastic guard and leaving the half-metal guard) half the blade would be exposed but only half of both faces and my hands would be further away. Of course, the edge of the blade would always be pointing straight at me inside the guard on the miter saw which is not always (but not never) the case with a large angle grinder.
I'm undecided if this is worth trying as a general reluctance to use something dangerous for other than it's intended purpose, but I'm not seeing the speed or safety issues as long as I were to fab up a solid clamping system. I think the dedicated chop saw is slightly safer, but I think the wood miter saw with an appropriate cutoff wheel is safer than using a large angle grinder. Safest of all would be just to pull out the hack saw.
Is there something else I'm missing?
