Miter Saws
Pen & Wrench
Huron, SD
I have owned a 12 inch Makita miter saw for several years and it has been really goodI have a Porta Mate stand for it. When I did a siding project where I needed to cut wider than it would cut I went for the DeWalt 12 inch slider with the LED lights, and I waited for a promotion to get a free stand came with it. I like them both. I wondered if I'd like the LED light, and how it shows exactly where the blade will cut, and after about 2 cuts, I realized, I didn't really absolutely need it, but I sure do like having it.
kctyphoon
Jersey/Staten Island
I have the 10-inch Ryobi slider and it is a great saw for the money. I cut the trim work (doors, baseboards and windows) for the entire first floor of my house. I managed to cut 7.5-inch baseboard with the saw by laying the baseboard flat. I only had about 30-feet of the wide baseboard to cut so I just worked around the saw's limitations for that one room. It is a single-bevel saw, so I had to work around that limitation sometimes as well, but it really wasn't that big of deal.
https://www.homedepot.com/p/Ryobi-15-Amp-10-in-Sliding-Miter-Saw-with-Laser-TSS102L/205216332
The 12-inch version is on sale now for $199- which is the same price as the 10-inch.
https://www.homedepot.com/p/Ryobi-15-Amp-12-in-Sliding-Miter-Saw-with-Laser-TSS120L/205673791
The Rigid miter saw stand is fantastic. I bought it for $99 on Black Friday.
https://www.homedepot.com/p/RIDGID-Universal-Mobile-Miter-Saw-Stand-with-Mounting-Braces-AC9946/206992161
I’d consider the Ryobi a good choice also.. for $20 more though you get a lot more features in the Craftsman unless you took advantage of the sale if the 12” Ryobi slider is the same price as the 10”. Still, big saw, heavy saw, no compact rail system means it’ll take up twice as much room when being used.. this is all a matter of personal choice though, and i think any of these is a good buy for the money. Miter saws are such standard tool it’ll never matter what brand most people buy.
stonesfan68
Houston, TX
kctyphoon, I tagree. If you're not making a living doing trim carpentry then you really don't need the fancy Bosch. (As much as I wanted the Bosch slider I just couldn't justify it!) The results are really a result of the carpenter working with the tools at hand. Buy a good blade, take your time measuring, practice with some scrap pieces and you should be good to go.
James-W
Southeastern Wisconsin
So - your logic is its worth spending what’s half of a lot of people’s mortgage payment on a saw set up that you admit will only get used occasionally, and because its a good brand, it’ll last until someone is too old to use it, and wont cost much if you break down the payments over half a lifetime.. now sell me on what he should buy if he was a professional that was using it everyday to make a living and lets see if you arrive at a different conclusion on what the “most pratical” choice should be..
I sincerely dont comprehend the idea that the most expensive pro option is a good choice for the guy that will hardly use it, entirely based on the idea “cause its what the pro’s use”
OP - just think - you can cut that cost in half in you buy it when you’re 10 and use it till your 90.. I’m curious, why we dont have a forum full of people using antique tools.. just sayin..
If we follow your logic he should get a wooden miter box and a handsaw because after all, he only uses it occasionally.
Whether you use a tool every day or you use it only occasionally, you want the tool to do the job you need done. He may never need to cut a 2X12 but if he does it would be nice to have a saw that could do it. It is no different than building a garage. Build one that is large enough to do the things you want to do. Building a small garage that may not meet your needs just because it is cheaper is not a good reason to do it that way, at least to my way of thinking it isn't.
How many times has someone you know bought something and then later on they had to buy a better one because the one they bought didn't meet their needs? Personally, I have seen this happen numerous times over the years with friends of mine and in the end more money is spent than if they had just gone ahead and bought the better one to start with.
You can buy whatever you want. As for me, I will get the better one because then I only have to buy it once. I am retired so I don't use my tools a lot. But when I need a tool to do a job, I want the tool to be able to do it. If the opening poster gets a 10" miter saw, he will be limited in what he can do with it. If he never needs to saw anything other than a 2X4 from time to time, then he will have no problem with that saw. But what if he does? What happens if he has a project next month that requires him to cut some larger pieces of wood? It is far better to have more saw than you need than to have less saw than you need.
Miss the Pontiacs
Saskatchewan Canada
Xs 2 Totally agree we You James. 20+ years ago I purchased a 10” Delta compound miter saw. It was what I could afford but when cutting 6” stock you had to give the material a little flip. When installing some commercial cork flooring I couldn’t buy my 12” slider quick enough. I’ve used it plenty and plan on using it plenty more. Have to admit had to buy a bunch of new 12” blades. But my table saw, RAS and my compound miter will make good use of my existing 10” blades.
I
icthruu74
I picked up the CM 10” compact slider today and have put a few dozen cuts on it after mounting it on my stand and squaring the fence and bevel. So far I’m very happy, even the blade that came on it cuts smooth enough for me so far. For me this is a tool that’s going to spend most of its life sitting on a shelf, and isn’t job critical.
