mitsubishi mini wiring
motorcycle79
wisconsin
just got a mutsubishi mini split mr slim and the i ran a 14/2from the outdoor unit to the indoor unit.. my question is i went to wire it s1 and s2 is power just thought s3 was a ground untill i see another ground screw on the indoor unit am i a wire short? if so what that s3 for? thanks for the help
battmain
You need to specify which models of indoor and outdoor units. Some run 230v to the indoor unit. With the model numbers, the install manuals can be accessed to answer your question. :)
Here is an example of the needed information for the mini split I'm setting up...
M
motorcycle79
wisconsin
did not buy online when i first looked i thought i only needed 14/3 untill i went to wire and saw the other terminal. thanks for the help
dejar59
Motorcycle79 - quick questions about your mitsu mini. How much did it run you and where did you find one? What sq ft will it handle?
Thanks for the help
WVBrady
WV
I think you are confused by the notation. As HVAC Phil said, you need 14/3 plus ground, which is a total of four wires.
mpire
Florida
The LGs just require some 18g wire from the outside unit to the inside unit.
M
motorcycle79
wisconsin
i was confused i had a 14/2 and saw other lug and need 14/3 is what i ment to say thanks for straighting me out
M
motorcycle79
wisconsin
Thanks for the help
$2,285.45 bought at local wholesale house 2 ton with heat pump not sure how much it handle as the wholesale sized it
